Go to Post One team at the UTC regional scored over 2100 points in autonomous alone. I was highly impressed. - Greg Marra [more]
Unread 21-11-2008, 01:59
CraigHickman
Posts: n/a
Re: gear ratio
Originally Posted by squirrel View Post
The lower ratio (9:1) will give a faster moving robot.
Originally Posted by Madison View Post
...operating with the unwritten assumption that all other things are equal.
Yeah. 9:1 will (probably, depending on the motor...) give you a higher top speed. Acceleration is a totally different ball game, and requires some really fun math that no one ever got around to teaching me. (to be totally honest, I'm not a math guy.... Hence the Sociology major)
I seem to recall from my lurking there being a spreadsheet floating around that calculates acceleration as well as top speed for FRC bots... Am I mistaken? Anyone know where this tool is?
Unread 21-11-2008, 04:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: gear ratio
Originally Posted by Dick Linn View Post
Does anyone have some actual numbers of how fast their robot managed to go as a percentage of the max unloaded motor RPM? I mean as-built with gearbox loss, etc. I'm not interested in feet/sec. figures. I was just wondering if something like 80% was realistic.
It's pretty close. 968 did a test of actual ground speed vs calculated theoretical speed of our 2008 robot. The actual speed was approximately 80% of the no load 100% efficiency speed.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-11-2008, 09:56
Brandon Holley's Avatar
Re: gear ratio
Was that calculated from the ~5500 free speed CIM RPM ? Or were you assuming some sort of amperage being pulled?
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 21-11-2008, 15:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: gear ratio
No-load = free speed. That is, the speed the motor turns at when nothing at all is connected to it. Note, that this doesn't mean no amps are being pulled. There's still a small amount of friction to be overcome etc. Plus, the rotor coils are constantly changing orientations and making and breaking contacts. This means the magnetic fields are constantly collapsing and reforming, which means the back emf generated by the motor will vary over time. Since the voltage supply nominally stays the same and the coils have some resistance, current is flowing whenever the back emf doesn't exactly equal the input voltage. So all DC motors have a no-load current as well as a no-load speed.
Which brings me to another silly technical point. Since the CIM is drawing current it has some non-zero input power, even at no-load. However, since there isn't a load output from the shaft, it has zero output power. So the motor's efficiency at no-load is actually 0%, not 100%.
Unread 21-11-2008, 16:39
Cory's Avatar
AKA: Cory McBride
Re: gear ratio
I was referring to no load in the sense of robot sitting there with wheels in the air-ie:no load on the gearbox, not no load on the motor. I was a little unclear there.
As to the second point, I meant 100% efficiency as in zero frictional losses in the drivetrain, not 100% motor efficiency.
2001-2004: Team 100
motor/gear ratio starsROBOTICS Motors 5 24-03-2008 10:02
Last Year's Gear Ratio AndyB Technical Discussion 4 11-11-2007 01:17
Transmission gear ratio MASherry Technical Discussion 6 13-01-2005 10:32
Helical Gears Gear Ratio Joe P Technical Discussion 11 23-01-2003 22:55
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
