#19
Re: pic: Mecanum Musings
Great design. Do the nuts and bolt ends miss the carpet? You may want to look into tapping one end of the c-section and countersinking the clearance on the other. Then you could use a flat head screw and match the length of the screw to the c-section width. Then you should be able to avoid any hardware overhang and further reduce the weight. Typically you should have at least three full threads for any bolted joint.
Keep up the great work and please post your final version! |
| pic: vex mecanum 1 | psyco_klown | Extra Discussion | 9 | 05-05-2008 23:22 |
| Musings from a FIRST Inspector | Wayne Doenges | General Forum | 36 | 26-02-2008 21:31 |
| pic: Mecanum Prototype 1 | Doug G | Extra Discussion | 8 | 06-04-2007 21:34 |
| pic: 1" mecanum | Tytus Gerrish | Extra Discussion | 8 | 04-10-2005 13:44 |
| Sweet Repeat musings........................ | skrussel | Off-Season Events | 3 | 19-10-2003 23:33 |
