| Let's swap data! |
#16
Re: Shifting Two Anymarks with One Pistion
Team 716 has been using a single 1" stroke cylinder since the off season of 2003. The single cylinder generally locks in one gearbox before the other which can give some pretty interesting movements if you shift during autonomous!
We build an adapter to screw on the back side of the cylinder with a 10-32 screw sticking out to match the piston rod. |
#17
to save more weight and air you could use servos to shift
also i was thinking about somehow shifting two with on small motor if we get a small enough one in the kit? |
#18
Anyone wanna weigh in on servos? |
#19
it saves more air for use because i think we used 1 inch pistons to shift in the past not 1/2
#20
we used them on our 2007 robot and they worked good(not as well as the pnuematic shifting though)enough to allow the robot to do wheelies, using servos would be less complex,I've never had a servo break before, and you could probobly replace that piston with a single, small, motor(like the fischer price maybe) and shift both(dont know if this would work any better but the idea is out there now) |
| Shifting with easyC | Erics626 | Programming | 1 | 24-01-2006 18:58 |
| One or Two Wheel Shooter | Nitroxextreme | Technical Discussion | 6 | 14-01-2006 01:10 |
| [ECDU]:one or two | Michael Leicht | FIRST-related Organizations | 16 | 09-12-2004 07:23 |
| one control stick or two? | 346operator | Technical Discussion | 24 | 12-08-2004 09:59 |
| Control system with one joystick(or two) | CharlieWilken | Technical Discussion | 3 | 04-02-2002 09:20 |
