Go to Post You won't find this in a manual anywhere but you will need COUGH DROPS!! If you haven't started losing your voice by Friday afternoon, you aren't getting the full experience. - wendymom [more]
Unread 22-11-2008, 19:18
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Shifting Two Anymarks with One Pistion
Team 716 has been using a single 1" stroke cylinder since the off season of 2003. The single cylinder generally locks in one gearbox before the other which can give some pretty interesting movements if you shift during autonomous!
We build an adapter to screw on the back side of the cylinder with a 10-32 screw sticking out to match the piston rod.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 22-11-2008, 19:33
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
to save more weight and air you could use servos to shift
also i was thinking about somehow shifting two with on small motor if we get a small enough one in the kit?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 22-11-2008, 19:55
CraigHickman
Posts: n/a
I have to say, I'm not entirely a fan of shifting with servos. I would want my drive train to be the most durable, reliable, and least complex mechanism possible. The added complexity and small (easily breakable) parts of servo shifting makes me a little nervous. Now, I have to say: I've never actually tried servo shifting, but have done pneumatic to much success.
Anyone wanna weigh in on servos?
Unread 22-11-2008, 21:01
trigger's Avatar
trigger trigger is offline
AKA: David
FRC #0842 (Falcon Robotics)
Team Role: CAD
trigger is an unknown quantity at this point
it saves more air for use because i think we used 1 inch pistons to shift in the past not 1/2
Unread 22-11-2008, 22:51
gorrilla's Avatar
AKA: adam spears
we used them on our 2007 robot and they worked good(not as well as the pnuematic shifting though)enough to allow the robot to do wheelies,
using servos would be less complex,I've never had a servo break before,
and you could probobly replace that piston with a single, small, motor(like the fischer price maybe) and shift both(dont know if this would work any better but the idea is out there now)
Adam Spears
Shifting with easyC Erics626 Programming 1 24-01-2006 18:58
One or Two Wheel Shooter Nitroxextreme Technical Discussion 6 14-01-2006 01:10
[ECDU]:one or two Michael Leicht FIRST-related Organizations 16 09-12-2004 07:23
one control stick or two? 346operator Technical Discussion 24 12-08-2004 09:59
Control system with one joystick(or two) CharlieWilken Technical Discussion 3 04-02-2002 09:20
