Go to Post The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start. - DonRotolo [more]
Unread 23-11-2008, 10:11
MorbidAngel's Avatar
MorbidAngel MorbidAngel is offline
FTC #0392
MorbidAngel has a little shameless behaviour in the past
Encoders and distance (labview)
I'm trying to program for autonomous, using the encoders. However, the formula I'm using for finding the right number of ticks for one inch and such isn't working. Does anyone have a formula, or an input value for a distance of one inch? I'm using LabVIEW. Help me please ^^
Unread 23-11-2008, 11:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Encoders and distance (labview)
If you're using the encoder VIs, then they should be doing 4x decoding. That is, they'll return 4 ticks for every cycle of the encoder. So if your encoder is 1024 pulses/cycles per revolution, the VI will actually read 4096 ticks per revolution. After that, it's just properly figuring how many inches you have per revolution.
Unread 23-11-2008, 11:53
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
This is difficult to do without more information. Needed is: Ticks/rev of the encoder used, Gear ration in the drive AFTER the encoder has sampled, wheel diameter.
Unread 23-11-2008, 12:18
The formula you are looking for is this
distance = (ticks) * (Gear Ratio) * (wheel diameter * pi)/(ticks per rev * scale)
Where Gear ratio is amount of times the wheel spins per amount of times the encoder spins, and scale is 4 (per what Kevin said above).
As I last saw them, the WPI Robotics Library encoder VI's had provisioning for real world unit distance feedback. The VI's had setters and getters for the gear ratio and distance travelled, respectively.
Labview 8.5 and encoders MorbidAngel NI LabVIEW 1 15-11-2008 13:57
Help with Angles and distance charlie1218 Programming 5 13-12-2007 18:54
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
EEPROM and Encoders Bharat Nain Electrical 7 01-12-2005 10:06
Testing and Cause of Failure for Encoders and Hall Effect sensors ChrisH Electrical 28 19-09-2005 01:07
