Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
Unread 23-11-2008, 13:56
DavidB DavidB is offline
FRC #2753
DavidB will become famous soon enoughDavidB will become famous soon enough
Beginner Electrical
Hello this is my first year in FRC. I'm interested in doing the electrical but I need to do a lot of reading up on my own. I was wondering if anyone had any suggestions on what to begin reading in order to get the basics down. Beginning
with basic electrical and explaining the parts and different uses of the FRC electrical system, 2008 stuff is good to seeing as the 2009 controller is just beginning to come out. If anyone has any good links that they like I would appreciate. Thank you in advance for any help you can give me.
DavidB
P.S. Sorry if this is in the wrong part of the forum. I figured the electrical section was the way to go.
Unread 23-11-2008, 14:55
Re: Beginner Electrical
The FIRST 2008 Guidelines, Tips, & Good Practices document goes over a lot of good stuff.
Unread 23-11-2008, 15:29
FRC #2753
Thank you. That's the kind of stuff I was looking for. This should help alot thanks again.
Unread 23-11-2008, 15:36
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Hey David!
Yes I would recommend what was posted before. I also like a lot of the stuff in here, http://first.wpi.edu/Workshops/index.html. There are some good presentations on the electronics of older and newer system (like under 2007, "Wiring an FRC Robot", and rookie workshops).
Welcome to CD (Chiefdelphi).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 24-11-2008, 00:42
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
I would make sure to take a peek at the power distribution diagram and the data connectivity daigram.
http://www.usfirst.org/community/frc....aspx?id=10934
It is where i started, but the best way is to have someone there to help guide you through what is going on.
The diagrams probably will look complicated to you at first (they were to me) but if you stare at it for a minute you can figure out that all it is is following lines which represents wires. If you dont have anyone to help you, then just make sure you read up on all the rules of wiring the bot. These will be released at kickoff. The main thing is to make sure that you have everything wired correctly and using the right gauges of wires.
Remember, if you cant figure something out then just ask on CD and you will probably get an answer pretty fast.
Unread 24-11-2008, 08:14
FRC #2753
Thanks for the advice. All the stuff looks like it will help
Unread 01-12-2008, 14:50
David,
Please look at the control system wiring and manual and check the FIRST website for updates to the electrical system often. They change. Check over the 2008 Robot Manual Section 8 and the 2008 Inspection documents. Although there will be some changes, most of the electrical rules are used from year to year. If you have any other concerns or specific questions, please PM me for a quick response.
Unread 01-12-2008, 15:00
384 huband44's Avatar
384 huband44 384 huband44 is offline
AKA: Wayne Huband
FRC #0384 (Sparky)
Team Role: Electrical
384 huband44 has a little shameless behaviour in the past
hey david
i was just wondering what was the most helpful site that the other members sent you
it could help
cause im new too
Unread 02-12-2008, 14:34
FRC #2753
Hey Huband44,
The Power Distribution diagram was probably one of the most helpful. Also Section 3 of the FRC Manual is a good read to I believe samir13k posted it. http://www.usfirst.org/community/frc....aspx?id=10934 (if that doesn't work just look at his post)
David
Unread 03-12-2008, 20:19
AKA: Samir Shaikh
FRC #4329
Talking Re: Beginner Electrical
Originally Posted by DavidB View Post
Hey Huband44,
David
Make sure you keep a copy of that with you when wiring!!! It will be your best friend until you have it memorized!
Unread 09-12-2008, 21:25
Led235's Avatar
Led235 Led235 is offline
Zach Kurth... GO Jags 1785
AKA: Zach kurth
FRC #1785 (1785)
Led235 is an unknown quantity at this point
Exclamation Re: Beginner Electrical
I am a first year person too. I just burried my head in electrical booksa and what not, oh and my soldering area at home is a Humungous pile of motherboards, CPU's,laptops,batteries,solder, and alot of other junk!
Go Team 1785!
Electrical Crewman
CAD / Inventor MASTER!
Beginner easyC questions Toonzaka Programming 1 28-05-2008 08:42
Beginner PHP Project Raven_Writer Website Design/Showcase 3 23-05-2004 16:47
Beginner problem with downloading pagemauck Programming 2 17-01-2004 13:24
Good Beginner Websites mistresshawk Programming 27 18-01-2003 10:45
