Go to Post With a one-on-one-on-one-on-one-on-one game it would be really easy. - dlavery [more]
Unread 21-11-2008, 21:23
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: pic: Mecanum Musings
that mecanum looks really good, reminds me alot of the WPI wheel from 2005 except a little smaller. Do you have a view directly from the side so we can see the complete arc of the rollers?
Unread 21-11-2008, 21:46
CraigHickman
Posts: n/a
Sure, let me grab a render real quick. I'll edit this post in a minute with it.
There's two renders here: My 1.0 ultra-cheap design, which is with 6 rollers. It's outer diameter is around 4, 4-5 inches. Next is the 8 roller one, a bit smoother, and a little bit larger with a effective diameter of 6 inches.
Unread 21-11-2008, 22:00
Originally Posted by Andrew Schreiber View Post
Jason, would mounting two of them like that really work? I mean I suppose it would but has anyone ever done it with Mecanums?
I've driven a platform with doubled AndyMark mecanums, and it works just fine. It almost looks like they were designed to be able to be mounted that way.
Unread 21-11-2008, 22:35
Joining the 900 Meme Team
FRC #0079
Ok, thanks, Ive just never seen anyone do that.
Unread 22-11-2008, 19:02
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Great design. Do the nuts and bolt ends miss the carpet? You may want to look into tapping one end of the c-section and countersinking the clearance on the other. Then you could use a flat head screw and match the length of the screw to the c-section width. Then you should be able to avoid any hardware overhang and further reduce the weight. Typically you should have at least three full threads for any bolted joint.
Keep up the great work and please post your final version!
Unread 22-11-2008, 19:31
CraigHickman
Posts: n/a
No, there's plenty of clearance for the hardware holding the rollers to the C channel. I'd really prefer to not take any more material out of the C, as the goal here was to go cheap and easy (hence going with aluminum from McMaster. If I go to something stronger (like a higher strength alloy), Then possibly I'd work on lowering the profile a bit.
I'd love to post the final version, but for me all designs are a work-in-progress. Maybe I'll post some renders side by side with a real thing if these actually get built? It's all really up to the team for what they'd like to build. I am just a mentor, anyway.
Unread 22-11-2008, 19:43
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Just a mentor? You say that like it's unimportant...
Unread 22-11-2008, 19:49
CraigHickman
Posts: n/a
I understand the importance of the position, but I see the limits in the spot. I'm here to teach students about engineering and smart decision making, not win them a competition. If that were my job, you'd be seeing a lot more designs up here that I "planned" on making, and justification on why they're the best.
Instead, I spend my time designing and planning parts and mechanisms with the intent of showing students that there are more possibilities than the most complex (high school students seem to be good at finding the most difficult solution first...) and expensive option.
A mentor should teach the team, not BE the team in my opinion.
Unread 23-11-2008, 18:41
AKA: Ryan
FRC #2614 (MARS)
You're completely right. My apologies for getting off topic.
Also, for the rough ride concerns: Once I make the wheel wider, and thus the rollers longer, the wheel actually smooths out a good bit.
How wide do you think the wheel would have to be to give a smooth ride?
Unread 23-11-2008, 19:06
CraigHickman
Posts: n/a
About 3 inches wide, then it's pretty much smooth.
Here's a render of the latest revision. It's little bigger (effective diameter of 8ish inches), and uses more machining resources. to shave weight off.
Once I hit a revision that i feel comfortable putting on a robot, I'll be hosting the CAD for anyone that wants it, with only one rule: if you make it or modify it, you also have to put the CAD up. It's time to bring Open Source to robotics, folks.
Unread 23-11-2008, 19:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
can you render it with a viewpoint that's much further away, so the view of the side of the wheel is "flat"?
also....open source is nice! we did some this past season, I know we inspired a few teams
Unread 23-11-2008, 19:21
CraigHickman
Posts: n/a
I'm not understanding this, sorry.You're asking for a view that's in orthographic, not perspective, and from a "front" of the wheel view, or a "side" (front being looking at the narrow view, what I have in the middle there, "side" being the one on the left)?
Unread 23-11-2008, 20:25
MrForbes's Avatar
AKA: Jim
side view, as in looking at the side of the robot. The view in the left of your picture above. Change the perspective to infinite, so you can see how "round" the wheel is.
Unread 23-11-2008, 20:27
Brandon Holley's Avatar
I've spent some time designing mecanums (on a smaller scale), and I have my own method, but I was wondering if you would share the method you used to create the curvature of the roller. Specifically in CAD terms (I'm very familiar with any CAD system), what you did to ensure your roller curve was as effective as possible.
Thanks in advance!
Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-11-2008, 20:56
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
The only question i would ask would be if they were to be bumped into would they break easier or would they still have enough strength.
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
pic: vex mecanum 1 psyco_klown Extra Discussion 9 05-05-2008 23:22
Musings from a FIRST Inspector Wayne Doenges General Forum 36 26-02-2008 21:31
pic: Mecanum Prototype 1 Doug G Extra Discussion 8 06-04-2007 21:34
pic: 1" mecanum Tytus Gerrish Extra Discussion 8 04-10-2005 13:44
Sweet Repeat musings........................ skrussel Off-Season Events 3 19-10-2003 23:33
