Go to Post I know that it's often dangerous to use common sense in a YMTC thread... - Kris Verdeyen [more]
  #31   Spotlight this post!
Unread 22-11-2008, 21:59
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: pic: Night & Day
Yeah, I'd like to see some actual weights too.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #32   Spotlight this post!
Unread 22-11-2008, 22:01
Joining the 900 Meme Team
FRC #0079
If no one gets to this I can do it Wednesday.
  #33   Spotlight this post!
Unread 22-11-2008, 22:09
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Victor: 101.1 grams (.223 lbs)
Jaguar: 166.5 grams (
.367 lbs)
Ecck!
(on the flip side the jaguar's do come with nice little stickers!)
By the way, if anyone else wants to know the weight of anything I be glad to measure it.
Edit: Updated with correct weights.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
  #34   Spotlight this post!
Unread 22-11-2008, 23:38
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Originally Posted by Lowfategg View Post
Jaguar is 162.5 grams (0.358 lbs)
Victor is 97 grams (
0.21 lbs)
Ecck!
Like the cRio with modules, 1677.8 grams (
3.699 pounds)
Yeah, Me also. I already have all the weights of the bot parts...i wont have them with me until monday though. If you need em' just pm me
  #35   Spotlight this post!
Unread 22-11-2008, 23:55
AdamHeard's Avatar
Lead Mentor
0.21 lbs)
Ecck!
3.699 pounds)
IFI lists the Victors as .25 Lbs, even then, it's a good deal heavier.
  #36   Spotlight this post!
Unread 23-11-2008, 00:10
Lowfategg's Avatar
AKA: Tyler Moser
Well that was with my triple beam balance, from what I can tell there ..223 lbs (mass).
  #37   Spotlight this post!
Unread 23-11-2008, 00:23
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
what about the weight of the old power distribution block, maxi fuse panel, and other fuse panel combined vs the weight of the new PD board
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
  #38   Spotlight this post!
Unread 23-11-2008, 02:18
Originally Posted by samir13k View Post
I got our kit today, and i saw the pro and the con of the jaguar
Pro: good performance, SURPRISINGLY LIGHT WEIGHT!!!
Con: looks even bigger in person (at least i think)
The surprising lightness is because they're fluffy. They aren't as heavy as you'd expect from the size, but they're still more than half again as heavy as a Victor.
I too was struck by how much bigger they are in person than I was prepared for from the pictures. They're huge.
  #39   Spotlight this post!
Unread 23-11-2008, 10:12
Lowfategg's Avatar
AKA: Tyler Moser
Well, it seems that my scale was off, so I calibrated it (the wonders of analog technology). These weights are hopefully more accurate.
.223 lbs)
.367 lbs)
Sorry about that!
  #40   Spotlight this post!
Unread 23-11-2008, 17:30
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
150% larger,
150% heavier,
lets just hope it performs more than 150% better =)
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
  #41   Spotlight this post!
Unread 24-11-2008, 00:12
AKA: Samir Shaikh
FRC #4329
Originally Posted by Burmeister #279 View Post
150% larger,
150% heavier,
not to scare anyone, but id say it is way more than 150% larger...actually i'd say about 225% larger at least
at least i have had no problems with them. I would actually say that installation is a little easier since it is bigger, and they have also performed great so far!
(u can probably spot the pro and con of that second sentence i wrote)
  #42   Spotlight this post!
Unread 24-11-2008, 08:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I think burmeister forgot that area is the square of length. So the length is 150% larger... but the area, well....
  #43   Spotlight this post!
Unread 24-11-2008, 09:45
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Yesterday we figured out a nifty space-saving way to mount these, and I'll post a pic tomorrow night once I put the memory card back into my camera so it will save the picture
Take a 1/16" wall angle aluminum piece that has 2.5" legs (hard to find I know, we had to cut metal meant for another purpose to get it), drill holes that are far enough up and apart so that a Jaguar can be vertically mounted to it. Then, mount the Jaguars back-to-back on the mount -- but -- rotate one of the Jaguars 180 degrees on the axis that's normal to the mount plate. This will put all of the motor outputs on one side and all of the power inputs on the other. Then, using either a 3" #8 bolt & nut, OR a #10 2" machine screw, you can screw the Jaguars to each other. For a production mount piece, you can mill out unnecessary metal from the middle and still maintain the rigidity.
WARNING: A #10 machine bolt will thread the inside of the holes. We haven't done shock testing yet with this setup, so YMMV for longevity of the mount.
Other than that, your power distribution block will need plenty of room on each side! This isn't room for wiring, no, it's room so that you can horizontally put a tiny screw driver in the slot in order to take a wire in or out. You can't do this from the top of the PDB, nor really effectively at an angle. The PDB was the single deciding factor in the majority of our preliminary electronics layout. Could someone point us to an effective tool that has a flat 90 degree tip, to alleviate that problem?
GitHub
  #44   Spotlight this post!
Unread 24-11-2008, 09:49
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Every time this thread pops up I get Cole Porter in my head.
  #45   Spotlight this post!
Unread 25-11-2008, 07:21
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
When I saw pictures like this on CD I thought that they were going to be like GINOURMOUS, but they really are not that big, and they feel like there construction is of much better quality, like it is a "top of the line" type product. I actually like them, and don't really mind the size, because they pretty much are equal in weight.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
pic: CRT T-SHIRT Shooter At Night Kyle A Extra Discussion 7 21-09-2006 13:04
pic: Atlanta at Night (cloudy) Joe J. Extra Discussion 7 01-05-2006 21:24
pic: Mayhem Night Crew Tytus Gerrish Extra Discussion 7 11-07-2005 00:55
pic: David Kelly's long night D.J. Fluck Extra Discussion 3 20-03-2005 23:23
pic: 696 - The 1st late night CD47-Bot Extra Discussion 22 17-02-2004 06:45
