Go to Post FRC is about what we collectively make of it. - Tristan Lall [more]
Unread 24-11-2008, 14:34
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Question about Mecanum code
I was looking at a few sets of mecanum code and was wondering about a few things.
Whats the best way to make sure there is no under/overflow in the code?
Is it necessary to have the wheels perfectly square?
i found some code that uses the distance to the XY center point of the axels to the center of the bot in the code, and that tells me that its only to tell where the axis of rotation is for Z.
Thanks for the help.
~Burmeister
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 24-11-2008, 16:10
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Question about Mecanum code
Most of the time the precise positioning of the wheels isn't needed, but they should be reasonably close. In general if normal wheels would work then so will Mecanums.
To prevent overflow issues you can use a larger data type to store the intermediate calculation. For example if your inputs and outputs are in the range of -100 to 100, then if your variable can handle values from -300 to 300 you shouldn't experience any overflows, and since the next step up from a char is a 16 bit integer, which holds -32768 to 32767, then you won't experience any overflows unless you input data is incorrect.
You should also confirm that the output values are in an acceptable range.
As for exact code most of the time something like this is all you need to get a reasonable output. You can add additional logic, like a PID loop for encoders, but its not needed for a simple robot.
This code is from memory, but it should be correct.
//This is just some generic C-like syntax, but you should be able to
// use it for the old robot or the new controller assuming you use C/C++.
// If you use Labview you'll need to port the logic into that language.
Wheel names:
Front of robot
NW     NE
SW     SE
int NW, NE, SW, SE; //Variables which will hold the calculated values
int X, Y, Z; //X sideways movement, Y forward movement, Z rotation
NW = Y + X + Z;
NE = Y - X - Z;
SW = Y - X + Z;
SE = Y + X - Z;
//Check output are in a valid range here
//You can check the outputs are in range with somthing like this
//Assuming your output range is -100 to 100
if (NW < -100)
     NW = -100;
else if(NW > 100)
     NW = 100;
//Assign outputs to motors or motor control loop here
Eric Haskins KC9JVH
Question about Solenoid and default code waialua359 Control System 4 21-01-2006 18:21
question about the code naor52 Programming 1 10-01-2006 16:42
Question about kevin's code ImmortalAres Programming 3 23-06-2005 11:13
One last question about our code dddriveman Programming 5 22-03-2004 09:49
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
