Go to Post Robotics season has monopolized my time for the past several weeks so I have not been keeping up with Segway news lately - Stu Bloom [more]
Unread 09-10-2001, 13:02
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Machining Gears on a Mill
The HOT team has successfully cut steel gears on a mill. It was the year before I joined the team so I don't know all of the details.
In '99 they didn't have the SPI budget to buy the gears for their custom drive train so they made them. They made 20 pitch, 20 degree pressure angle gears in a variety of diameters. They were made on a CNC bridgeport with an index head. I'm not sure whether an index head is the same as a divider head.
They started with the proper diameter cold rolled steel round stock from SPI and a full set of gear cutters (you need different cutters for different sized gears). The gear cutters they used are like fly cutters except with involute profile shaped teeth. They cut several gearwiths at a time and then parted the desired facewidths off in a lathe. The cut gears were nearly indistinguishible from purchased ones. Even though the gears were not heat treated, there were no problems with durability. (They appeared to be oversized for the task though.)
If you have more questioins, I can get better information from the machinist who made them. Just send me an e-mail at James.L.Meyer@gm.com or post here.
It is my impression that with today's small parts budget you are better off buying SPI gears than trying to machine them this way.
Another solution to the Bosh motor gear problem is to press your own gear on the motor shaft. (Something the HOT team also did in '99)
Hope this helps,
Jim Meyer
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
