Go to Post I'd hate to state the obvious here...but I believe that we all just got Rick-rolled... - Hallry [more]
Unread 24-11-2008, 22:11
eccmaster eccmaster is offline
FRC #2344
eccmaster is an unknown quantity at this point
New Control System Subnet Question
We are having trouble with the directions for configuring the wireless communication for the new control system. The direction states that all the subnets should be 255.0.0.0. The wireless router can not be set to 255.0.0.0 it can only be set to 255.255.255.0. After I set subnet mask to 255.255.255.0 for the laptop and bridge, the control system worked fine over the wirless. Anybody else have this problem?
Unread 24-11-2008, 22:35
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
Re: New Control System Subnet Question
The 255.0.0.0 subnet mask is in reference to whatever device you are using to program the cRIO (laptop/computer). I'm pretty sure that the default subnet for both the wireless router and the wireless gaming adapter are fine.
For all of those who are reading this post, I would like to remind all to try and limit the technical control system discussions on chiefdelphi and perhaps consider using the public control system forum that FIRST has put out on their website.
Unread 05-12-2008, 19:27
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
I had to use 255.255.255.0 for the router and an using 255.0.0.0 for everything else per the directions and everything is working fine.
Mattehew Forman
MorTorq 1515
Unread 06-12-2008, 21:53
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We also used 255.255.255.0 for the router and 255.0.0.0 on everything else with success. I think the documentation needs to say something about 255.255.255.0 on the router, because the router will not let you change the subnet mask to 255.0.0.0
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 06-12-2008, 22:17
The latest version of the documentation says to use 255.255.255.0. See section 5.6.2 item 8b.
new control system Sam2197 FRC Control System 2 22-11-2008 13:17
New control system? David55 Rumor Mill 2 29-12-2006 08:28
A question about control system options computhief263 Control System 7 04-02-2004 14:46
PBASIC/control system question archiver 2001 1 24-06-2002 00:33
New Control System? smokescreen Rumor Mill 4 07-03-2002 15:48
