Go to Post I can tell you for a fact that students don't need smartphones in order to unproductively entertain themselves in a robotics lab. - remulasce [more]
Unread 24-11-2008, 23:10
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
Re: New Info on 2009 control system, maybe
Originally Posted by Kevin Sevcik View Post
Problematic and probably overkill. How do you implement default code that doesn't need to be changed to run a robot if missing a joystick means the robot won't run? Plus, disabling the whole robot when a joystick read fails probably takes more work.
It would only disable the robot if a joystick, which would have been enumerated at the beginning, produces multiple bad reads in a row. This way it would only disable if a joystick went missing while it was running, it wouldn't check at boot. Or you could have it check for joysticks at boot, and simply have four boolean values that need setting.
Team Leader
Team 1595
2009 Control System wedellm FRC Control System 11 23-11-2008 22:38
2009 Control System Layout Mark McLeod FRC Control System 36 23-11-2008 11:39
NEW 2009 Control System Released qnetjoe FRC Control System 296 15-08-2008 15:02
pic: 2009 Control System, Mounted Billfred FRC Control System 23 01-05-2008 19:02
2009 Control System Possibility? Racer26 Rumor Mill 121 25-04-2008 09:05
