New Ctrl Sys Early Ship - Benchtop Test
Hi -
We received our early shipment of the new control system today....just like Christmas a month early for the team! We ran through the benchtop test procedure this afternoon, and all worked fine except for Auton mode - following the steps in the benchtop test doc, nothing happened when we enabled Auton mode. This is with the out-of-the-box firmware, image, etc on the cRIO and DS. Has anyone else run into a similar problem? Trying to determine if this indicates a hardware defect (and we have to get a replacement from FIRST) or simply a problem with the default code that ships on the controller.... Thanks, Ron Team 2607 - Programming Mentor |
| **FIRST EMAIL**/Early Control System Ship Final Details | Mark McLeod | FIRST E-Mail Blast Archive | 0 | 19-11-2008 14:19 |
| Early Shipment of the New Control System | EricVanWyk | FRC Control System | 3 | 05-11-2008 13:51 |
| Early shooter test video | Qbranch | Robot Showcase | 2 | 03-02-2008 15:35 |
| Smithy or other Benchtop Mills/Lathes/CNC | Dan Richardson | Technical Discussion | 6 | 21-06-2007 22:32 |
| How early in the season did you get to test your programming? | EHaskins | Programming | 18 | 20-02-2007 00:22 |
