Go to Post Go with what you know will work, and try a little less if you are feeling brave. That is my rule of thumb. - sanddrag [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 26-11-2008, 18:22
LDavies562's Avatar
LDavies562 LDavies562 is offline
AKA: Leslie Davies
FRC #0503 (Frog Force)
LDavies562 is a jewel in the roughLDavies562 is a jewel in the roughLDavies562 is a jewel in the rough
Driver Station Blank Screen, Anyone have the same problem?
We are currently having significant problems with the Driver Station. We plugged everything in today, and initially got the status screen.
We attempted to update the firmware, yet that did not work even though we went 3/4 of the way through the button pressing process when I'm pretty sure we might have made a mistake and did not wait the whole three minutes.
We rebooted the DS and tried it again, yet now we have a blank screen with the occasional appearing cursor, and no status screen at all. By messing up the firmware update, did we delete the original firmware?
We posted on the FIRST Forums, as well as read through http://forums.usfirst.org/showthread.php?t=10503 None of the advice has proved successful for us.
Thanks in advance for helping us out. Any ideas would be great.
Unread 26-11-2008, 20:08
Re: Driver Station Blank Screen, Anyone have the same problem?
Originally Posted by LDavies562 View Post
...We attempted to update the firmware, yet that did not work even though we went 3/4 of the way through the button pressing process when I'm pretty sure we might have made a mistake and did not wait the whole three minutes.
The firmware is completely erased and replaced during the update process. If you didn't let the process finish, your Driver Station now has no firmware. There is a way to recover, but it means taking the cover off and soldering wires to the board, which will completely void the warranty. Contact FIRST and find out what they officially recommend for dealing with the situation.
Unread 26-11-2008, 20:14
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Wow, its that easy to brick a drivers station? I think FIRST is going to have a few of these on its hands.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 26-11-2008, 21:14
O-H
FRC #0048 (Delphi E.L.I.T.E.)
I think we should avoid speculating about things that may or may not come to pass related to the Driver Station. I think we should instead focus on providing constructive commentary directly related to the original poster's request for assistance in this thread, similar to what Alan provided. On top of that, let's provide some assistance and clarification to teams who have yet to undertake this procedure to help minimize the risk of a similar occurrence happening to their hardware.
First of all, it's been mentioned elsewhere, but the Table of Contents of Chapter 5 does not jive with the actual sections of the document. There is no Section 5.1 "Introduction" as referenced in the TOC, so all the TOC references are incremented one section higher than what is actually in the document. This is a trivial fix that should be made and reposted to the FIRST Control System webpage immediately. To those working very hard on the development and support of this new system and its related documentation, let's scour the existing published material and fix these minor errors, please. Let's also dot the I's and cross the T's of future documentation before releasing it publicly, please. Please don't risk wasting teams' precious time, and please don't make your support jobs harder by adding unneeded confusion to the process.
Documented Firmware Upgrade Process
Please refer to Section 5.1.1 (in the main document body, avoiding the Table of Contents)
Originally Posted by Section 5.1.1 of the Control System Manual
8. The firmware upgrade will proceed automatically. Do NOT interrupt this process by cutting
power to the Driver Station, inserting/removing any cables from the Driver Station, touching any
of the I/O pins, etc. The firmware upgrade takes approximately 3 minutes to complete.
9. The Driver Station will automatically reboot upon completion of the firmware upgrade.
So to the OP - you mentioned you may not have waited 3 minutes. Why did you choose to abort before the minimum duration specified in the instructions?
Step 9 indicates that the Driver Station should reboot once the firmware load is complete. Not having performed the exercise myself yet, it seems that the reboot would be a positive reinforcement that the firmware update has completed and that you should leave the Driver Station alone until the reboot occurs (or until a period of time much greater than 3 minutes goes by without any reboot occurring).
Can someone who has completed this process successfully please tell all of us what the Driver Station does when the firmware load is complete? What does a reboot "look" like when it occurs? What happens on the LCD screen? It sounds like this is the only form of feedback during the upgrade process - I presume nothing is displayed on the LCD that indicates the update progress while the transfer is taking place ("XX bytes of XX total copied", or something similar). If this is true.....can this be addressed in a later firmware release to give teams more feedback that something "good" is happening DURING the firmware upgrade?
Unread 26-11-2008, 21:33
The screen displays shown in 5.1.1 are what you see.
"DO NOT SHUT OFF!"
is the biggest clue.
If your flash drive has a status light, it'll blink as the download takes place.
After it reboots itself you see the standard screen
Team: 0000
Mode: Invalid
System: Invalid
Battery: No Comms
DS REV: 2008-10-29a
That "*** OTB ***" at the bottom is now gone.
Unread 26-11-2008, 21:57
O-H
"DO NOT SHUT OFF!"
Team: 0000
Mode: Invalid
System: Invalid
Battery: No Comms
DS REV: 2008-10-29a
Thank you Mark. That's helpful. Does the "checking file size" message at the bottom of the screen when "DO NOT SHUT OFF!" is displayed ever change to something else to indicate different states during the upgrade, or is that a static message throughout?
Unread 26-11-2008, 22:01
amk's Avatar
amk amk is offline
AKA: Ann Kowalczyk
amk is an unknown quantity at this point
The student who was doing the upgrade claimed the Driver Station performed a reboot (as it was supposed to) but upon rebooting, the Station was left in a bricked state. No intentional abort was executed, the DS was left alone and this is the result. As a mentor who was in the general vicinity but not directly supervising, I did not actually see what happened so I cannot back this up.
Is there any way to recover from this? It would seem that there should be a way to install firmware no matter what the state of the DS. Thanks for any suggestions...
Unread 26-11-2008, 22:08
That does change to:
"verifying integrity"
then
"updating system"
where it stays for a couple of minutes before rebooting.
Unread 26-11-2008, 22:16
I assume you tried putting the flash drive in, cycling the power, then holding down the two arrow buttons for a long time. If that doesn't kick off the firmware loading process, there's not much recourse other than to contact FIRST support directly.
Unread 26-11-2008, 22:28
amk's Avatar
amk amk is offline
AKA: Ann Kowalczyk
Yes, very many times, with every possible combination of USB port # & enable/disable, tele/autonomous switch combinations (hey, worth a try!). Why do these things always happen at the worst times? (holiday). Thanks for your suggestions!
Unread 27-11-2008, 00:08
With the available firmware images, there is no permanent boot loader. The process of updating completely erases the flash memory, and nothing is left to load a new image if the update does not complete. This is obviously not a good situation, and I'd expect it to be high on the "to be fixed" list for the DS. However, I don't have first-hand knowledge of the dealings between FIRST and the company supporting the DS, so I can't give any guesses as to when or if the ability to break things easily might be corrected.
As I mentioneed before, there is a way to install the firmware on a "brain-dead" Driver Station. It requires access to internal pins on the board, and perhaps other equipment that might not be available to most teams, so it's not a simple solution to the immediate problem.
Unread 27-11-2008, 00:46
Lowfategg's Avatar
AKA: Tyler Moser
Sorry about that, I just found it interesting.
Unread 11-12-2008, 17:11
Mike578 Mike578 is offline
FRC #0578 (Blue Lightning)
Team Role: Electrical
Mike578 is an unknown quantity at this point
Our team is having a similar problem to this, however, we did not update the firmware. When we plug in the driver station following the benchtop test directions, the screen backlight turns on along with the power LEDs, but nothing appears on the screen. No idea what is going on with it at this point, any help would be appreciated.
Unread 22-12-2008, 16:51
iwin2000 iwin2000 is offline
iwin2000 has a spectacular aura aboutiwin2000 has a spectacular aura about
Bump.
Does anyone have any solution to this?
Unread 22-12-2008, 19:34
There are two potential solutions.
The first is to return it to KwikByte to be restored to the factory default.
The second hasn't been santioned by FIRST, and may lead to worse problems, but KwikByte also offers a reflashing chip.
pic: The new driver station Billfred Extra Discussion 28 23-04-2008 20:07
pic: Why FIRST needs to make the driver station taller Jay Trzaskos Extra Discussion 12 12-03-2007 08:57
did anyone else have this problem? NuclearPeanut FIRST Tech Challenge 0 25-04-2005 14:34
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
Does anyone have this odd problem?? Adam Y. Motors 2 04-02-2003 16:39
