Go to Post With one post, Mr. Miller joins the top 0.7% of Chief Delphi, reputation-wise. I think the community supports him. - Taylor [more]
Unread 26-11-2008, 20:01
Ashwin Ashwin is offline
FRC #0115 (Monta Vista Robotics Team (MVRT))
Ashwin is an unknown quantity at this point
Send a message via AIM to Ashwin
New Control System - Wireless Problems
When running the benchtest to confirm the wireless, we hooked up everything according to the manual, section 5.6 (rev .3). After setting up everything as specified, we tried to connect to the IP through the laptop, but we were unable to access the wireless router through the driver's station. When we connected the laptop directly to the WRT610N Wireless Router, we were able to run through the configuration status, however, when we tried to configure the WRT600N, we were unable to connect through the IP specified. We made sure our connections were correct, and our laptop is set up as specified. Any idea how to continue from here?
MVRT - Monta Vista Robotics Team, Team #115
(Student Leader - Engineering, Driver, Coach - 2005-2009)
(Mentor - 2010-??)
2010 Chairman's Award Silicon Valley Regional
2009 Engineering Inspiration Sacramento Regional
2008 & 2012 Championship Best Website Award
Check it out - www.mvrt.com
Unread 26-11-2008, 20:34
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: New Control System - Wireless Problems
Did you connect to the WRT600N and configure it before you changed the IP on your computer?
If you have configured all the IP address as per the instructions then the problem is probably with the security settings.
Set up the passphrase on both the router and game adapter or disable the wireless security. They left that part out of the manual.
Unread 26-11-2008, 20:41
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
We (1501) had the same trouble, our wireless wouldn't work. When we ran through the manual 5 times, it still didn't work. What we found out is that the manual tells you to set the IP address of your computer to be the same as the WRT600N. If you look at one of the diagrams earlier in Chapter 5, it shows the setup of the devices with the IP addresses, and the PC IP Address is supposed to be 10.xx.yy.6, not 10.xx.yy.1. Once we did that, it worked just fine, as far as I know (I got a call once it was working).
Good luck
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
Unread 26-11-2008, 21:02
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Good luck
This and other noted documentation errors here and there underscore the need for FIRST to release typo-corrected documentation on their site ASAP. Even the most basic typo can lead to hours of delay and frustration for teams who are already on a compressed learning schedule as it is.
Unread 26-11-2008, 21:04
cooker52's Avatar
Cookie
AKA: Seth Cook
FRC #4272
Makes me glad that they sent out a lot of the systems out before kick-off. It'll definitely make the build season easier. Plus it should help the beta teams out by lightening the load on their shoulders.
Unread 26-11-2008, 22:17
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
The other main issue with wireless our team had was with the security settings. In Chap 5 of the control system manual, they do not tell you to either enable security in the WGA or disable it in the WRT. Out of the box and following the manual does not have the security settings matched. If you can ping all of the devices individually when they are connected with cables, but cannot ping the WGA when it is disconnected from the WRT, then that is the clue that the security settings are not correct. You can either disable security on the WRT, or enable the matching security protocol on the WGA (make sure you get the encryption key, AKA SSID key, from the WRT). Also, make sure that you cycle the power to the DS, WRT and WGA, the WRT and WGA; reboots do not get the job done. I tested this many ways with the security configs and they only work when they are matched. Now the interesting question is (besides did we do something stupid and are the only ones with this issue?) is that which security setting is correct (WPA2 or disabled, depending on the defaults)? Mama told me never to leave an access point open, so my bet is on WPA2.
Unread 08-12-2008, 00:57
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
Hi everyone! It appears we are a little behind everyone else, but I thought I would post this. We have gotten through the entire benchtop test except the wireless portion. We have hooked it all up per the manual but nothing happens in teleop mode when we are un-tethered. I'm ready to do all the firm ware updates but I've been warned so many times to not do any updates untill we have completed the entire benchtop test suite that I am a bit gun shy of moving on right now. Has anyone had similar problems or have any advice? Can we go ahead and put in the firm ware updates? Thanks!!
Jeff Austin
Team 2930
Unread 08-12-2008, 09:49
The wireless setup (1.6.6) comes after the firmware upgrade (1.6.5), so you're safe to proceed.
Unread 10-12-2008, 18:54
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
do you think that we'll be using our own routers during the competition? If not, will there be standards for what is and isn't allowed for encryption at the event?
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 10-12-2008, 22:38
We won't be using our routers at the event.
The competition port handles all the communication just as in year's past.
The DS will be powered through that as well.
Unread 10-12-2008, 23:33
galewind's Avatar
AKA: Chris Gregory
if we set our wireless bridges to authenticate with security on our routher, though, isn't that going to cause an issue when it tries to authenticate at the competition via a different means of communication?
Chris G
Unread 11-12-2008, 00:51
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
FRC #0115 (MVRT)
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
There is no need for security. So there will be no problem. I think the reason they had us all set up IPs standard was so that there would be no problem. I don't think that they will make us use a separate router cause that would require 3 plugs to be plugged into the driver station then. The DB-9 port, a RJ-45 port and a power connection. I would guess that they will have us keep the router and use it. Otherwise, why buy the most expensive router that linksys makes???
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
Unread 11-12-2008, 10:36
galewind's Avatar
AKA: Chris Gregory
if a team uses no wireless security and leaves their passwords as default on their wireless devices, what's to stop someone else from going in and changing passwords and wireless configuration settings from underneath of them, causing unnecessary stress on these teams? What do we have to prevent teams that don't exhibit gracious professionalism from doing nasty things with readily-available and commonly-accepted devices over a universally-used transmission protocol?
Am I misunderstanding this? Am I over-paranoid? Is this something that has been thought-through and just not shared with us yet?
Chris G
Unread 11-12-2008, 10:38
Yes.
Security is very important during competition. Usability is very important always. Therefore, you have an unsecured but easy to use system that will be locked down when it needs to be.
New Control System koka230 FRC Control System 14 10-12-2008 02:07
new control system Sam2197 FRC Control System 2 22-11-2008 13:17
New Control System Wireless Bridge Power? Greg Marra General Forum 3 21-09-2008 17:19
New control system? David55 Rumor Mill 2 29-12-2006 08:28
New Control System? smokescreen Rumor Mill 4 07-03-2002 15:48
