Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 29-11-2008, 16:50
Xaphiinia Xaphiinia is offline
FRC #1983
Xaphiinia is an unknown quantity at this point
[FTC]: Random Error with FTC motor control
We started from the standard 288 base code, which works well except our robot throws an error randomly from the FTC Move Motor.vi that causes it to stop working.
This error will continue the last action of the driver for maybe two seconds and then the robot will stop. We designed a function to indicate that the error has occurred through beeps. The error can be corrected by switching off the battery for approximately five seconds. We cannot figure out what throws the error though. Sometimes the error will throw itself every couple of seconds while other times the robot will run fine indefinitely, or at least until we turn off and on the program.
We modified the 288 scaling code to cap the maximum values in case of weird controller values, so we don’t believe that to be the problem. We also do not use the encoder values in our program.
Unread 29-11-2008, 17:03
ttldomination's Avatar
Sunny
Re: [FTC]: Random Error with FTC motor control
1. Which program are you using?
2. Do you believe it to be a problem with the code? If you think so, then post your code somehow and we'll look over it.
3. Do you think it's a problem with the motor controller? If this is the case, I think you should contact Pitsco with your problem.
1648: 2013-2014
5283: 2015
Unread 01-12-2008, 15:39
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
Make sure you have downloaded the latest updates. The latest FTC Move.vi seemed to fix our similiar issues.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
