Go to Post He is just one of the dozens of evil minions I have molded into my image over the years. Be afraid world, be very afraid. - Andy Grady [more]
Unread 29-11-2008, 15:33
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
downloading the WPI library off the SVN
I was downloading the WPI library through Windriver but when I entered the repository address it asked me for a password. The instructions say to just use your Sourceforge username and password but that didn't work for me. Anyone know whats up?
Unread 29-11-2008, 16:12
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: downloading the WPI library off the SVN
The sourceforge username and passwords are for the Beta testing forum, FIRST is working on putting the sourcecode on a public server.
The instructions need to be updated as well
Hopefully it will be ready soon.
-Borna Emami
Team 0x27
Unread 29-11-2008, 16:38
nickmagus's Avatar
AKA: Nick Clayton
Ok so how do I get code onto the robot in the mean time?
Unread 29-11-2008, 16:49
BornaE's Avatar
I did not do the c++ programming for the beta testing, so i will ask our tem member that did.
But to the best of my knowledge, you do not need the sourcecode for the libraries to run you code.
-Borna Emami
Team 0x27
Unread 29-11-2008, 21:43
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
0705920 is correct. You do not need the WPILib source to write code for your robot. I recommend starting with one of the example programs. Try File >> New >> Example.., VxWorks Downloadable Kernel Module Sample Project, Next >
Then choose one of the examples. "Iterative Robot Demo Main Program" worked for us. Then click "Finish".
Dave D
Unread 30-11-2008, 14:24
nickmagus's Avatar
AKA: Nick Clayton
thanks for the help.
Unread 30-11-2008, 18:54
nickmagus's Avatar
AKA: Nick Clayton
Could you clarify what the voltage reader is? The analog bumper is plugged in, is there a separate voltage reader that needs to be plugged in, I didn't see one in the kit of parts check list.
Unread 30-11-2008, 19:05
Could you clarify what the voltage reader is? The analog breakout is plugged in, is there a separate voltage reader that needs to be plugged in, I didn't see one in the kit of parts check list.
There is a 3 pin header above the 3x8 pin field. By installing a jumper, you may select the 8th analog input to either read the battery voltage or read what ever sensor you have plugged into the 8th row in the 3x8.
Unread 30-11-2008, 21:12
nickmagus's Avatar
AKA: Nick Clayton
thank you very much, that's good to know. I appreciate all your help.
Unread 01-12-2008, 23:31
AKA: Brad
#0190 ( Gompei and the Herd)
The source code is now put up on the WPI site here:
http://first.wpi.edu/FRC/frcupdates.html
This is a temporary thing until we get the SourceForge server up and running. Shouldn't be too much longer.
Brad Miller
Robotics Resource Center
Unread 11-12-2008, 10:15
Gaurav27's Avatar
Gaurav27 Gaurav27 is offline
Gaurav Bhatt
FRC #1241 (THEORY 6)
Gaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of lightGaurav27 is a glorious beacon of light
What is the URL for check out from SVN Plugin from Windriver? This is from the FRC instructions however they don't provide us with the URL.
2016 Newton SubDivision Finalists [254,1731,708]
2016 Waterloo Winners [610,3560]
2016 North Bay Winners [1310,2935]
2013 World Champions [1477,610]
2013 Galileo Division Champions [1477,610]
Unread 04-01-2009, 01:57
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Am I missing something? Or is this still an issue!? I can't find a link to the subversion server anywhere!
Unread 04-01-2009, 09:47
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
They haven't opened the SVN server, the last time I checked. Also, as a note, the code that is on the SVN server right now is the source code for all the WPI Library code (eg. RobotDriver.cpp, Gyro.cpp, etc.) The header files are installed when you install WindRiver Workbench.
On the first site there is a like to the current update (build 1562) is located here:
The larger file is the actual update, the smaller file is the source code for the WPI Library.
As if last week the 1562 build that is available above is either the same or more current the the SVN build on the beta WPI SourceForge site.
Note: Make sure you accomplish the benchtop test PRIOR to applying any of the updates. The instructions are tailored to the unmodified installed.
D. Sean Kelly
Beta Test Team #499
Unread 05-01-2009, 14:29
AKA: Brad
We're getting closer to having the SVN server there, so for now keep downloading the zip file with the source code in it. We'll let you know when it's ready.
Brad Miller
cRIO-FRC Training Video: WPI Library Overview BLAQmx National Instruments LabVIEW and Data Acquisition 5 09-11-2008 19:58
An Issue with downloading the Master Code. Neil [Coconuts] Programming 6 07-02-2008 14:03
Where is WPI Library Information PDF? koenig3456 Programming 2 15-01-2006 16:19
Downloading the DEfault program gjibben Programming 1 11-02-2004 21:20
