Go to Post It is NOT possible to fail within FIRST. It IS possible to fail within the competition (whatever your criteria for failure may be). - JVN [more]
Unread 30-11-2008, 17:16
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Re: [FTC]: 35's Drive problem
Originally Posted by gdo View Post
The NXT is faster, I think the lag has as much more to do with the bluetooth. I found that it was better to incorporate FEWER interface commands, where the code looks for the joystick commands, which definately has a slowing affect.
There are more factors, but the bluetooth speed is the biggest problem I think.
I have had very few problems with the bluetooth interface in RobotC, but I haven't been using the FTC Control station, but the included software in RobotC. It will be interesting to see what the robots will do at scrimages with the competition setup. (the only scrimage I went to, people used personal laptops and all used RobotC)
I can't see why it would be the blue tooth. They use blue tooth in a number of things (my Wii comes to mind), and they don't have laggy controls, it must be something in the code.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 30-11-2008, 21:39
Monty Python Monty Python is offline
Monty Python has a spectacular aura aboutMonty Python has a spectacular aura aboutMonty Python has a spectacular aura about
Bluetooth is not the problem. My team used to use Labview and there was lag even when using a USB. Also, the bluetooth was not a problem at the scrimmage I attended. Redownload the last Labview update as I'm not sure if they posted a new update, they may have just edited an old one (although I'm not 100 percent positive, this is just what I remember reading is one of the links on chief delphi). Labview had a ton of lag for us and RobotC has almost none. I would suggest trying to run the sample joystick code for RobotC and seeing if you have lag.
Unread 01-12-2008, 01:16
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
I would agree that it shouldn't be the bluetooth, unless it is the software implementation of it. I use a bluetooth mouse with my notebook and while hardcore gamers tell me there is some lag, I definitely haven't noticed it.
Team Leader
Team 1595
Unread 01-12-2008, 09:14
ttldomination's Avatar
Sunny
Well...we're not exactly running mouse from this. Idk, let's wait for an reply from labview.
1648: 2013-2014
5283: 2015
Unread 02-12-2008, 19:08
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
A quick update:
We put at deadband (+/-10) on the drive sticks and it has mitigated the problem. The underlying lag is still there, however. I'm sending our code to NI tomorrow. I'll keep you posted.
Unread 02-12-2008, 22:57
KayyPii's Avatar
KayyPii KayyPii is offline
FRC #1404 (SHOCKs)
KayyPii will become famous soon enough
I should really try the deadband thing.
By the way, anyone has any idea how far bluetooth signal goes?
=>"That hole you drilled is a little off."
=>"Don't panic, just make it bigger and put a washer on it!"
=>Eye ball once, and cut as many times as it takes
Unread 03-12-2008, 09:10
Sunny
How far do you want it to go? I doubt you'll have problems at competition.
1648: 2013-2014
5283: 2015
Unread 03-12-2008, 21:55
KayyPii's Avatar
FRC #1404 (SHOCKs)
That's true
Unread 03-12-2008, 22:04
wilsonmw04's Avatar
Coach
No one has been to a competition yet, so who knows what's going to happen. I see this as a quality control issue. If there is something slightly off with LabVIEW and the FTC hardware, I'd rather bring it to someones attention now and eliminate future problems. If this is just a coding error on our part, no harm no foul and my team and I learned something to boot.
Unread 04-12-2008, 10:05
Sunny
Well, there have been plenty of scrimmages. So, I'm sure if there were range problems at the scrimmages, then they would have been brought up.
1648: 2013-2014
5283: 2015
Unread 04-12-2008, 14:22
wilsonmw04's Avatar
Coach
Did those scrimmages use the regulation field control system? I have a feeling that we are going to see some interesting bugs tomorrow in U-Hall.
Unread 04-12-2008, 15:03
I attended a scrimmage where they used the regulation stuff, it was run by the NJ FTC people. There were very few problems and things went far smoother then I expected.
Unread 04-12-2008, 15:50
Sunny
First regional is tomorrow? Well, be sure to take lots o' pics for me?
1648: 2013-2014
5283: 2015
Unread 04-12-2008, 16:06
I'll be driving, but I'll try to take a couple.
Unread 04-12-2008, 21:45
wilsonmw04's Avatar
Coach
Update: While i was having my students do some commenting on the code before we sent it to NI, we noticed something interesting: we has 4 motor controller VI's where there should have been two. When we removed the extra two, the lag disappeared. We live and learn don't we?
[FTC]: Problem with two controller setup in Labview wilsonmw04 FIRST Tech Challenge 2 11-11-2008 19:58
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: Team 35's Servo Test wilsonmw04 FIRST Tech Challenge 11 03-11-2008 21:47
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
pic: FTC 35's prototype for 2007 wilsonmw04 Extra Discussion 2 08-11-2007 18:38
