Go to Post "For once, the cake is NOT a lie." The cake claims liar's paradox. :p - JesseK [more]
Unread 01-12-2008, 13:48
Aren_Hill's Avatar
Build Nifty Things
pic: Mousetrap car for engineering class
Unread 01-12-2008, 13:49
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
Re: pic: Mousetrap car for engineering class
nice! can you give us more details on how it works? sounds like a fun, little project.
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
Unread 01-12-2008, 13:58
Aren_Hill's Avatar
Build Nifty Things
sorry for the short explanation, i had to run to class.
okay, here's how it works
using rc car parts the front two wheels are setup with an ackerman system which is spring loaded to point them forward.
the back axle (which the string winds around from the mousetrap) is mechanically linked via small delrin chain to a piece of UMHW 1/4-20 threaded rod. This threaded rod has a small aluminum "trigger" on it that can't rotate wit the rod hence when the back axle rotates its motion is transferred to linear motion of the "trigger" by the threaded rod.
as the "trigger" moves across the rod it hits a steering linkage at some point hence turning the wheels, and it pops past the linkage so the wheels return to straight.
and just for overkill i'm planning on having it stop right after it crosses the finish line just to show that i can lol
mission accomplished
A guy who likes robots.
Unread 01-12-2008, 14:05
James1902's Avatar
James1902 James1902 is offline
Chopsaw??
FRC #1902 (Exploding Bacon)
Team Role: Marketing
James1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond repute
sick, the only mousetrap I have ever built only had to go in a straight line. I like yours a lot better
-In case of major discrepancies it's reality that's got it wrong
-oink oink boooooooooooooooooooooooooom
-Iz it can b pig go boom time now plz?...kthanxbye!!
Unread 01-12-2008, 18:35
ParkerF's Avatar
ParkerF ParkerF is offline
Learn it. Teach it. Spread it.
AKA: Parker Francis
FRC #0118
ParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond reputeParkerF has a reputation beyond repute
What are your material limits and what kind of floor are you running on? If you can, and you wanted more traction for your CDs, you can take a balloon and cut an end off, and fit it around the edge. We did wooden mouse trap cars as a project my freshman year in IPC. I doubt you need the little traction it will add, but why not?
Team 148 Alumnus - '07-'11
Team 3481 College Mentor - '12-'14
Team 118 Mentor - '17-Present
Unread 01-12-2008, 18:52
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Yeah, the same thing I had to do in H.S. As fast as you can go in a straight line across the cafeteria floor, no turning involved though. All we had to worry about was weight, friction and wheel diameter. Throwing a turn in the mix would have been more interesting.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 01-12-2008, 19:54
Aren_Hill's Avatar
Build Nifty Things
i am planning on putting a balloon strip around at least the back wheel and most likely all wheels, to avoid any spinning or skidding (as this would throw off the run).
Its running on a tile floor so the balloons will help
http://www.chiefdelphi.com/media/photos/28597
that is the car i made for my senior year physics class in high school.
as far as materials go we can use anything we can get, no cost limit just as long as nothings radioactive. And being part of the Iowa State solar car team, i am definitely making a carbon fiber spoiler simply because we have a large scrap pile of it...
Unread 02-12-2008, 00:50
germanystudent's Avatar
germanystudent germanystudent is offline
Trashed and Scattered
AKA: Everett
FRC #2865 (Roboteknix)
germanystudent has a spectacular aura aboutgermanystudent has a spectacular aura aboutgermanystudent has a spectacular aura about
Send a message via MSN to germanystudent
i loved doing moustrap cars in my class! one problem i've noticed with the cd wheels tho, on cement or even tile, they tend to spin out a bit.
Nobody leaves my reality without a note from their mother!
Unread 03-12-2008, 12:44
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Geez, yours is intense compared to our classes. All we had to do was have it go exactly 10 feet, and then we had timed tests and tractor pulls for extra credit...and we were only allowed to use 1 mousetrap!
Unread 03-12-2008, 13:40
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Ahh, Mouse trap powered engineering. We had to build a mouse trap powered string climber at UCSD. Object was to out climb the other entries. The day of the competition I put in a new and fresh mouse trap spring. Mine slammed itself into the ceiling on the first run and destroyed it self. One run and I was out of competition but I was the only one to ever reach the ceiling. LOL
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 03-12-2008, 18:11
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Ours projects was having to go 18ft power by the mouse trap....
I used K'nex wheels and axels that ran through holes in a 1/2 inch think piece of wood, where the mouse trap was hot glued on. And only usig a 1/8 piece of string about 2 ft long went the distance and sometime more...
I still have it and can take pictures to show off if anyone interested..
Also it would be nice to see some pictures of others...
(Idea a sperate mini mouse trap car races at FIRST events and mini awards for innvoation!
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 10-12-2008, 04:38
techedguy's Avatar
techedguy techedguy is offline
Technology Education, PFHS
AKA: Sal
FRC #4520 (Roboteknix)
techedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nice
Has anyone else had to do this project with a load added to the vehicle? I have my students design the vehicle around carrying a 12oz canned soda. I've dubbed it the "Can-Dew" challenge and it gives us a good excuse to buy a lot of soda and have a fun and stressful day trying to beat each other for distance. Rules are (1) Mousetrap as the sole source of power...only 4 holes in the Mousetrap allowed (for mounting purposes only) and other than that it's pretty open to whatever they want to try.
Unread 10-12-2008, 16:00
AKA: Samir Shaikh
FRC #4329
yup! Our class is only allowed 1 mousetrap, no alterations allowed to the spring, flippy thingy mechanism, only allowed to take off the hook, locking mechanism for when the trap is set. (we just held the flipper thing down).
Anyways, we had to have a hook on our car so that a sled could be attached to it, the sled was light, and we would add weights at like 50g increments. Once the field was down to 2-3 cars, we would have larger increments until 1 of them showed signs of weakness. (pull distance was 5-6ft, cant remember)
And we are not allowed to have any soda We are in a computer lab
Unread 10-12-2008, 16:56
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Mousetrap cars are awesome. Back in my day, the competition I did was scored as the product of the mass of the vehicle and the distance traveled. This being almost 15 years ago, I don't remember the exact numbers, but most vehicles were somewhere in range of a few hundred grams. Mine was almost 2 kilograms (I used a large block of 2x4 as the main base). It also traveled the second furthest of all, probably somewhere in the 10-20 meter range.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 11-12-2008, 23:34
Nightfall831 Nightfall831 is offline
AKA: Paul
FRC #0888 (Robotiators)
Nightfall831 will become famous soon enoughNightfall831 will become famous soon enough
Send a message via AIM to Nightfall831
Nice car, i like the design for turning!
we did mousetrap cars last year, the main issue was getting the car started cause the gear ratio was too high, so I build a CVT for mine :-)
It was basically just a wedge, and i wrapped the string around the bigger part to get the car started, then as it unwound it would go to the smaller part of the wedge to move to a higher ratio.
That's a PEBKAC problem. (Problem Exists Between Keyboard And Chair)
^Yea, I never run into those...
Survey for Engineering Class SSMike Chit-Chat 11 26-09-2008 12:23
pic: Another Mousetrap Car Jeff K. Extra Discussion 1 07-04-2008 17:42
pic: mousetrap car Aren_Hill Extra Discussion 24 20-12-2007 00:58
pic: mousetrap car Aren_Hill Extra Discussion 20 12-05-2007 12:08
