Go to Post Perfection of a system comes not when you can add nothing more but instead when you can remove nothing. - Andrew Schreiber [more]
Unread 28-11-2008, 22:43
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
windriver projects
I have extensively read up on the WPI library and I understand it really well, however I was unable to find any documentation as to how one is supposed to create the projects compile the code and get it on the cRIO. I have updated the cRIO and have updated the DS but I'm unsure as to how I get my C++ compiled and on the robot. Can anyone help me out here?
Unread 28-11-2008, 23:47
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: windriver projects
The documentation you're looking for is the "C/C++ Programming Guide for FRC", presently available only on the software DVD that came with the control system. It will walk you through the process of creating projects, connecting to the cRIO from Wind River Workbench, and downloading the code.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 30-11-2008, 21:54
Racer26 Racer26 is offline
I can't even seem to find that guide looking through both of the DVDs and the folders it installed on my pc... WindRiver was complaining about not being able to connect to the registry either.
Unread 30-11-2008, 23:28
Circuit Breaker
You're right, I can't find it on the DVDs, either - however, it did get copied to my hard drive in the C:\WindRiver\docs\extensions\FRC folder.
Patrick Fairbank
patfairbank.com
Unread 01-12-2008, 23:29
AKA: Brad
#0190 ( Gompei and the Herd)
That's were it gets installed to. It's on the DVD as part of one of the install packages. It also updates with the update self extracting zip files. The latest update is here:
http://first.wpi.edu/FRC/frcupdates.html
Brad Miller
Robotics Resource Center
Windriver Workbench Demo Videos neutrino15 Programming 8 27-11-2008 00:06
Programming Projects b_mallerd Programming 11 28-01-2007 21:53
My Projects... Shlomi32 SolidWorks 0 09-02-2006 23:10
Projects Raven_Writer Programming 0 18-09-2003 15:54
summer projects oreocookeee Chit-Chat 1 05-07-2002 23:17
