| Thread Tools |
Rating:
Display Modes |
Could use some help with joysticks . . .
Posted by Dan at 1/24/2001 9:51 PM EST
Student on team #112, Gear Grinders, from Buffalo Grove HS and Motorola. As a team, we have had problems with the joysticks for the past 2 years (since we've existed ). They keep wanting to 're-calibrate' themselves, i.e. the center, and extreme values vary from use to use. To combat this effect we have tried duct tape on the trims and adding buffer regions in software for a 'neutral zone' in the center of the joysticks' axes. Can any other veteran teams give us a hand in telling us a better method for this? |
Re: Could use some help with joysticks . . .
Posted by Mark Garver at 1/24/2001 9:56 PM EST
Student on team #68, Truck Town Terror, from Waterford Kettering/OSMTech Academy and General Motors Truck Group. In Reply to: Could use some help with joysticks . . . Posted by Dan on 1/24/2001 9:51 PM EST: I can speak as a veteran member of the Truck Town Terror (#68) team, there is no good way that we have found. We run into the same problem amost every time we run our robot. : As a team, we have had problems with the joysticks for the past 2 years (since we've existed ). They keep wanting to 're-calibrate' themselves, i.e. the center, and extreme values vary from use to use. To combat this effect we have tried duct tape on the trims and adding buffer regions in software for a 'neutral zone' in the center of the joysticks' axes. Can any other veteran teams give us a hand in telling us a better method for this? |
Posted by Dave Cannell at 1/26/2001 1:28 PM EST
Other from none. In Reply to: Re: Could use some help with joysticks . . . Posted by Mark Garver on 1/24/2001 9:56 PM EST: The joysticks used for R/C model airplanes don't seem to have neutral/drifting problems but I suspect they are LOTS more expensive... People who play lots of computer games should be able to provide some input about their favorite joysticks. |
Posted by Mark Garver at 1/24/2001 9:58 PM EST
update 5 says we can use any joysticks...
Posted by Anton Abaya at 1/26/2001 10:36 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .In Reply to: Could use some help with joysticks . . . Posted by Dan on 1/24/2001 9:51 PM EST: i say ditch those darn crappy joysticks and go get a logitech or a microsoft brand one... just make sure it isnt USB ;p -anton |
Joysticks
Posted by Nick at 1/28/2001 5:46 PM EST
Student on team #240, Mach V, from Jefferson Monroe High School and Visteon. In Reply to: Could use some help with joysticks . . . Posted by Dan on 1/24/2001 9:51 PM EST: Try replacing the potentiometer with a proper value resistor. It will always give you the same resistance. |
| reworking radio control for joysticks | ajlapp | Electrical | 5 | 05-12-2003 17:38 |
| RoboEmu v1.02 (now with real joysticks!) | rbayer | Programming | 2 | 02-10-2002 15:24 |
| Team 524 has Team 362's spare joysticks from last year. | archiver | 2001 | 0 | 24-06-2002 02:36 |
| Joysticks | archiver | 2001 | 2 | 23-06-2002 23:33 |
| Calibrating speed controllers and joysticks | thedillybar | Technical Discussion | 4 | 11-02-2002 13:24 |
