Go to Post If you build offensively, keep defense in mind always for defense will always keep you in mind. - Molten [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 23-06-2002, 23:35
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Could use some help with joysticks . . .
Posted by Dan at 1/24/2001 9:51 PM EST
Student on team #112, Gear Grinders, from Buffalo Grove HS and Motorola.
As a team, we have had problems with the joysticks for the past 2 years (since we've existed ). They keep wanting to 're-calibrate' themselves, i.e. the center, and extreme values vary from use to use. To combat this effect we have tried duct tape on the trims and adding buffer regions in software for a 'neutral zone' in the center of the joysticks' axes. Can any other veteran teams give us a hand in telling us a better method for this?
#0047 (ChiefDelphi)
Re: Could use some help with joysticks . . .
Posted by Mark Garver at 1/24/2001 9:56 PM EST
Student on team #68, Truck Town Terror, from Waterford Kettering/OSMTech Academy and General Motors Truck Group.
In Reply to: Could use some help with joysticks . . .
Posted by Dan on 1/24/2001 9:51 PM EST:
I can speak as a veteran member of the Truck Town Terror (#68) team, there is no good way that we have found. We run into the same problem amost every time we run our robot.
: As a team, we have had problems with the joysticks for the past 2 years (since we've existed ). They keep wanting to 're-calibrate' themselves, i.e. the center, and extreme values vary from use to use. To combat this effect we have tried duct tape on the trims and adding buffer regions in software for a 'neutral zone' in the center of the joysticks' axes. Can any other veteran teams give us a hand in telling us a better method for this?
#0047 (ChiefDelphi)
Posted by Dave Cannell at 1/26/2001 1:28 PM EST
Other from none.
In Reply to: Re: Could use some help with joysticks . . .
Posted by Mark Garver on 1/24/2001 9:56 PM EST:
The joysticks used for R/C model airplanes don't seem to have neutral/drifting problems but I suspect they are LOTS more expensive... People who play lots of computer games should be able to provide some input about their favorite joysticks.
Unread 23-06-2002, 23:36
#0047 (ChiefDelphi)
Posted by Mark Garver at 1/24/2001 9:58 PM EST
#0047 (ChiefDelphi)
update 5 says we can use any joysticks...
Posted by Anton Abaya at 1/26/2001 10:36 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
i say ditch those darn crappy joysticks and go get a logitech or a microsoft brand one...
just make sure it isnt USB ;p
-anton
#0047 (ChiefDelphi)
Joysticks
Posted by Nick at 1/28/2001 5:46 PM EST
Student on team #240, Mach V, from Jefferson Monroe High School and Visteon.
Try replacing the potentiometer with a proper value resistor. It will always give you the same resistance.
[IMG] code is Off
reworking radio control for joysticks ajlapp Electrical 5 05-12-2003 17:38
RoboEmu v1.02 (now with real joysticks!) rbayer Programming 2 02-10-2002 15:24
Team 524 has Team 362's spare joysticks from last year. archiver 2001 0 24-06-2002 02:36
Joysticks archiver 2001 2 23-06-2002 23:33
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
