Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 03-12-2008, 01:52
davidf davidf is offline
FRC #2850
davidf will become famous soon enoughdavidf will become famous soon enough
Re: FRC Game in 2009
I am new to first, however I have been using LabView for a while at my job and I have a few things to say about it.
1) It is an extremely powerful development environment. Programming in LV may take a while to learn, however once you understand the programming structure, it is much faster to do complex tasks then a similar C or C++ application is.
2) The FRC version of LabView is not, from what I can see, limited, and includes several expensive toolkits including NI Vision.
You are basically limited by hardware constraints and your imagination only. For my work (electrical engineering, RF) I have used labview quite extensively. It would be relatively simple to create a program that searched for objects of various shapes, sizes or colors. It would not be much harder to drive up to them and get a closer picture. Perhaps read a sign and follow its instructions (OCR vi's come in NI Vision that make character recognition straight-forward) or do some complex pattern recognition to sort objects into categories from the field.
Some limitation will be camera focus - I'm not sure if the camera for 2009 supports controlling focus via software - which would be necessary for reading close up text, barcodes, etc.
I know that building a FRC "robot" is challenge enough when it is remotely operated - but I think LabView will make autonomous actions much more feasible and maybe someday FRC will become an all autonomous competition.
For those of you who don't know it: The robot can be programmed remotely via the driver station and a laptop. This also means you can build a frontend on the laptop, e.g. any kind of control station you want on the laptop to give visual feedback or run pre-programmed drive loops or whatever the rules allow. Out of the box you can start a new LV benchtop vi that lets you see what the camera sees and all the analog, digital, pwm, and battery states directly on a laptop.
And perhaps next year when they enable the advanced functionality of the motor controllers-you will be able create feedback loops-and combine this with internal and external sensors (think gyroscopic sensor + accelerometer) and you can have much greater motor control, similar to what is used by Honda and others to build walking, upright android robots.
This kit your receiving is very much a professional, industry standard setup, if you go into electrical engineering / control systems engineering, you can expect to see much of the same software and equipment at your job.
[Official 2008 Game Design] OK, so YOU design the 2009 game... dlavery FRC Game Design 69 23-08-2009 19:54
FRC 2009 Game Manual? xanarchyx General Forum 56 14-11-2008 22:56
**FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams Goobergunch FIRST E-Mail Blast Archive 1 06-01-2005 09:29
