Go to Post Consider yourself mentored, you have learned a lesson: "Don't stick your hands in icky things." - Amanda Morrison [more]
Unread 03-12-2008, 02:04
Nameless Nameless is offline
FRC #0074
Nameless is an unknown quantity at this point
Interrupt on driver station digital input
Is it possible to attach an interrupt to a digital input on the driver station? I would like to use an encoder as an input device, and I don't believe there is any other way use them than with interrupts. I looked through the WPILib beta 5 code and didn't see anything about driver station interrupts in DriverStation.h/cpp and FRCComm.h.
If this isn't possible, I'm considering using a microprocessor to take in the encoder readings, keep track of the encoder offset, and output that as a PWM signal to the driver station analog input. For example, if the encoder is turned halfway around, the microprocessor would send a 50% PWM to the driver station. Would this work correctly? Also, does the driver station have a power source I could use? (As I understand it, external power is not allowed.)
For the visual people:
Unread 03-12-2008, 08:35
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Interrupt on driver station digital input
You can't interrupt on the digital inputs on the DS. If you're using a very coarse encoder (4-8 cycles per revolution) you might be able to manage it by simply sampling it every data packet from the DS... If it isn't turned too fast.
That said, if you're only interested in the angular position of the encoder is there any reason you can't use a plain old potentiometer to do this? There's stopless potentiometers if you need it to roll over, or multi-turn ones if you need a couple of turns. Expending all that effort to turn an encoder into just a potentiometer seems a little... excessive.
Unread 03-12-2008, 10:07
You would have to put a low pass filter on your PWM signal for the analog input to read it properly. If you post the specific frequency you will be duty cycle modulating, we can help you design the filter. It won't be much more than an RC network or two.
There is a 5V power supply on the DS that you can use, it is set up just like the DSC.
Unread 03-12-2008, 10:51
I'd transplant the encoder out of a USB joystick into the mechanical controls, while keeping the encoder attached electrically to the original processing hardware.
Unread 03-12-2008, 11:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Has anyone cracked open the Attack 3's? We've drilled them to mount them, but we didn't break them open. Is the "thumb wheel" on the base an encoder, or a potentiometer?
Unread 03-12-2008, 11:48
You can also buy encoders with an analog interface, like the US Digital MA3. http://www.usdigital.com/products/en...ary/shaft/ma3/
Unread 03-12-2008, 18:54
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
Have we been allowed to create custom processing circuits and attach them to the OI in past years?
Portable computing devices
must not be connected to joystick input ports on the Operator Interface.
Where do they draw the line?
Team Leader
Team 1595
Unread 04-12-2008, 00:03
FRC #0074
Ah, my fear was right about the lack of interrupts. Thanks for the ideas, everyone. I didn't know about the 'portable computing devices' rule, and that definitely invalidates my workaround idea.
However, the stopless potentiometers and analog/absolute encoders look interesting. I've heard of stopless potentiometers before... do they come that way, or do they have to be modified to become limitless?
Unread 04-12-2008, 08:31
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Our team used the US Digital MA2 and MA3 on the robot each of the past two years with excellent results. They are small, extremely accurate, reliable, durable, and have no "dead spot" like a stopless potentiometer. I would highly recommend these for applications where "continuous rotation" is needed.
That said, I have never used the MA2 or MA3 on a Driver Station, but they should work just fine!
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 04-12-2008, 16:55
AdamHeard's Avatar
Lead Mentor
I agree, whatever you were trying to do with an incremental encoder on the controls side could probably be done with an absolute encoder with an analog output, or probably even a continuous pot.
I imagine the code would be simple enough to just check the value each cycle and compare it to previous to get the "distance traveled".
Big Caveat, It's been forever since I really sat down and programmed.
Securing the Driver Station? Madison FRC Control System 16 16-12-2008 03:05
driver station doesn't see robot nickmagus Programming 4 29-11-2008 23:58
2009 Driver Station Dimensions noxryan FRC Control System 5 27-11-2008 21:02
pic: The new driver station Billfred Extra Discussion 28 23-04-2008 20:07
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
