Go to Post Everyone please breathe before you post. - Jessica Boucher [more]
Unread 03-12-2008, 16:34
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
pic: One of Team Overdrive's new toys
Unread 03-12-2008, 16:51
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: pic: One of Team Overdrive's new toys
Wow. What a beauty. I have a 1920's Logan lathe in my garage (same size). Dad has a 12" Southbend with a 6' bed that appears to be the same vintage. I am a huge fan of antique machinery.
My Logan has a built in cover/tensioner over the belt and back gears. It may be a good idea from a safety perspective to cover the belt and back-gears as there is a reason that modern lathes have these gaurds. Oh, used cookie sheets make excellent chip-pans.
Unread 03-12-2008, 17:09
Lowfategg's Avatar
AKA: Tyler Moser
Lol, if you look an the bottom right corner of picture that thing on floor is a cookie sheet I am going to use.
I am planning on adding some guards before I let my teammates start using it. I rather everyone keeps their figures.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 03-12-2008, 18:39
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Awesome. I didn't notice the cookie sheet before, but see it once you pointed it out.
These old lathes can be wonderful machines. I made 6" internal bearing lands for a sports racer a friend and I built. I also cu through 4" of steel for the spool drive. With practise and a good Machinist Handbook (if you don't have one buy one), you will be able to do amazing things.
I did update my Logan with a quick release tool changer. This is a significant time saver as the Southbend/Logan 1/2 moon adjuster must be re-aligned every time you change operations. I found a set somewhere for about $250 that had the head unit and 4 tool holders (1 parting tool, 2 turning/facing, and 1 knurler). I kept the old unit, but have not used it since.
Here is the Harbor Freight link. I don't think I bought the Harbor Freight unit, but something very similar.
http://www.harborfreight.com/cpi/cta...emnumber=34816
Unread 03-12-2008, 18:46
Lowfategg's Avatar
AKA: Tyler Moser
Ya, I was thinking of buying one of the quick change ones but I am going to see how the lamp tool post does first (it does look neater). I already put that 3 jaw chuck on it because the 4 jaw that was on it was a pain to use. As for machinery hand book, yes I am getting one, but for now I have the good old How to Run a Lathe by South Bend (sadly the 1920s copy was trashed so I have a 1950s copy).
Unread 03-12-2008, 19:13
Tyler, guess who found a mint condition copy of the 1920's one
Well, not me. Ha.
Did find an American Scientific pocket guide from 1920 that uses a South Bend to illustrate the functions and implementations of a lathe though, good enough for me.
Unread 03-12-2008, 19:54
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
hahahahaha i just finished reading that book. it is really good and i recommend it to anyone who is learning how to use a lathe.
If it isn't broken, Fix it till it is ~ Baker
Unread 03-12-2008, 20:19
Lowfategg's Avatar
AKA: Tyler Moser
Wish they made one for the mill.
Unread 03-12-2008, 21:40
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
nice i have one but mine a bit older mine ped-metal lathe so you had to pedal it as you worked
i can't see how people could do it it hard to stay balanced as your work
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 03-12-2008, 22:21
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
That's where the freshmen come in.
All freshmen labor jokes aside, it would be very hard to pedal while you machined.
-Vivek
"we don't build robots, we build people"
Unread 03-12-2008, 22:22
Lowfategg's Avatar
AKA: Tyler Moser
Yes I have seen those online, there pretty cool.
This one has 1/4 hp of pure custom built power. It runs very well for how old it is. Just motor hum, gear clicking, and belt nose only thing I could careless for is backlash, but I have seen worse on much newer.
Unread 04-12-2008, 09:22
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Lucky you! That is a fine looking machine.
I see you are from NJ - too bad Henry Ford moved a chunk of Menlo Park and brought it here to Detroit (Dearborn). Because you can see a lot of the early machine tools there. So fun to look at, and not much has changed from the early days of machining.
(OK, CNC is a nice add....)
Brian Graham
Unread 04-12-2008, 14:53
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Hi All,
this looks like memory lane to me.....it' the same as the machine I learned on years ago.
Try Enco or CDCO for your quick change tool holder set (about $90)
CDCO has the best deal on economy chucks
Books: web search for "American machine tool" they have a nice Free downloadable packit on both lathe and the mill operation
also the Home shop machinest is a good starter book,
Great project, Have Fun!
Geo.
watch the oz, the lbs take care of themselfs
Unread 04-12-2008, 16:42
Lowfategg's Avatar
AKA: Tyler Moser
Originally Posted by George View Post
Hi All,
Geo.
The chuck in the picture is from CDCO and I can see why the quick change would be nice, then again the lantern style is very adjustable.
I will probably pick up one of the machinist hand books off amazon for cheap.
Hey it cut 1/4" 28 tpi just fine for me a minute ago.
Also I be uploading a WAI in front of our Bridgeport which I also rebuilt (theres a story behind that one).
Unread 05-12-2008, 10:53
#0060 (Bulldogs)
Hi low,
When you say "Lantern style" are you talking about a rocker tool post?
(sometimes there is an east coast / left coast gap in terminology)
the advantage to quick change is that you can set up multiple turning or form tools and switch out with out resetting center hight
or when coupled with a DRO using tool offsets and maintain a true position
(Shooting Star makes an affordable DRO, but the best is Newall)
Geo.
[FTC]: Team Overdrive's robots close up photos Lowfategg FIRST Tech Challenge 0 26-07-2008 23:05
[FTC]: Team Overdrive's New Video Lowfategg FIRST Tech Challenge 1 15-06-2008 20:17
pic: Team Overdrive's #74 robot Lowfategg Extra Discussion 9 06-03-2008 16:53
pic: Arefin playing with my toys Tytus Gerrish Extra Discussion 13 09-10-2005 23:28
