Go to Post Batteries are like clamps or money, you can never have enough. - IndySam [more]
Unread 03-12-2008, 20:48
Skipwich Skipwich is offline
AKA: Skip
FRC #0177 (Bobcat Robotics)
Skipwich is an unknown quantity at this point
Exclamation Weight Specs for FIRST competition
Our team just received the shipment for the controls for this year's robot competition. We noticed that, after assembling all the sections needed for controlling the robot (not the driver's board) onto a test-board, we noticed that the new controls system is considerably heavier than its predecessor. My question is did FIRST change the weight limit for the robots in this year's competition because of the fact that the new controls system is heavier than the old controls system?
Thanks-
Skip
Unread 03-12-2008, 20:49
Re: Weight Specs for FIRST competition
Thanks-
Skip
We don't know yet. Wait until January.
Unread 03-12-2008, 20:58
ttldomination's Avatar
Sunny
This is an interesting question.
Obviously we don't know yet,
but think about it though. Wouldn't it be like FIRST to keep the weight limit the same or about the same just so that we would face a greater challenge this year?
It'll be interesting.
1648: 2013-2014
5283: 2015
Unread 03-12-2008, 21:36
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
At least we dont need spikes for the solenoids anymore!!!
Unread 03-12-2008, 21:39
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
AFAIK, OSHA Safety regulations limit the weight to be lifted by two people to 150 lbs, approximately the weight of an FRC robot with bumpers and battery attached.
If FIRST were to raise the weight limit, there would either have to be a lighter solution for either battery or bumpers, or teams would need to start carrying the robots with three members of their drive teams.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 03-12-2008, 21:41
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Thanks-
Skip
Consider it just another engineering challenge
___________________
- Tennyson, Ulysses
Unread 03-12-2008, 22:33
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Does anyone have an exact OSHA rule to quote? Upon searching the OSHA website I found the following:
http://www.osha.gov/pls/oshaweb/owad...S&p_id =24876
Question: Is there a policy or guide which states the maximum weight a person may lift?
Reply: OSHA does not have a standard which sets limits on how much a person may lift or carry. However, a sister agency, the National Institute for Occupational Safety and Health (NIOSH), has developed a mathematical model which helps predict the risk of injury based on the weight being lifted and accounts for many confounding factors. The model is based on previous medical research into the compressive forces needed to cause damage to bones and ligaments of the back.
Doesn't look like there's strict rules, just recommendations by NIOSH NOT OSHA.
Unread 04-12-2008, 07:57
A little further investigation and you will find that the limit is set by weight, and number of times lifted during a day. The 150 lb limit is stretching it but is within the guidlines as I remember. The MK batteries are a slight bit lighter than the Yuasa from earlier competitions. Still 120 (robot) + 13.82 (battery) + 15 (bumpers)=148.82 lb. I am hoping the GDC will allow lighter alternative interconnect cables for all the hardware of the control system though.
Unread 04-12-2008, 08:33
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
maybe they are planning the game around this new found extra weight. could be that it will require everyone to downsize a bit to find ways to be quick and able to fit in small spaces
Unread 04-12-2008, 08:38
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
... I am hoping the GDC will allow lighter alternative interconnect cables for all the hardware of the control system though.
Is there a solution? Are there lighter cables to be had/bought? Would the GDC consider allowing us teams to cut the cable length? (assuming the team has the proper expertise of putting on a new cable end).
Personnally-I doubt there would be allowances made.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 04-12-2008, 08:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Heck FIRST could even reduce the weight allowed and make a new design challenge for us all.
Just like everything else you never know what they may have up their collective sleeves.
Unread 04-12-2008, 08:46
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I thought they were going with LabView because the program is lighter and compensates for the electronics....
Hi!
Unread 04-12-2008, 09:33
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
After literally running with a 135lb robot in tow through the Atlanta tunnel to get to our match right after lunch on Friday (and missing lunch too ), I am an advocate for reducing the maximum allowed robot weight. At competitions like Philadelphia '08 where there are only 40 robots and each team has 11 qualifications, there is potential to have to carry the robot on and off the field up to 13 times in a 6 hour period on Saturday.
We could return to something like the tiered weight system again, where 6' tall robots may only be 100lbs, 5' @ 110, and 4' @ 120, or a reduced starting footprint tiered system. This means that bulkier bots have to be lighter so they're easier to handle off the field.
There is aluminum wiring available, but specifically banned by the rules for safety reasons. It tends to start fires if too much current is drawn.
GitHub
Unread 04-12-2008, 10:51
It is perfectly fine, electrically, to replace the bulky 37-pin cable to the Digital Sidecar with a lighter and shorter ribbon cable. That's not an insignificant weight savings. However, we won't know until the rules are published whether or not it will be legal to do so.
Unread 05-12-2008, 07:45
Dana,
Alan (above) is correct, short, custom, ribbon cables can significantly lighten the load. You may also not need all connections within a 37 pin cable and that would allow a further reduction in the weight. Just by shedding the bulky connector housing and hardware, I would guess you could loose several ounces. Packing all the bulk of the control system (fully decked out) into the robot is going to be a challenge as well. The RF rules for the wireless port will be similar for past radios. Mount the unit so that it is not buried down inside the frame where it's output is shielded by metal components and handle all cabling with care. i.e. no sharp bends, pinch points, etc. and secure the case and all wiring to the robot frame.
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman General Forum 85 08-01-2005 00:16
i need specs for motors and pumps in the kit from last years competition plz help SCYTE16 Motors 3 18-11-2004 22:54
FIRST Competition Entry Fee Increases for 2005 Travis Hoffman General Forum 78 03-06-2004 23:33
Signal specs for FIRST contorllers Tim Skloss Technical Discussion 6 31-08-2003 18:30
Post Competition and Pre-competition needs for 271 Chubtoad Technical Discussion 4 21-03-2002 12:17
