pic: One of Team Overdrive's new toys
Re: pic: One of Team Overdrive's new toys
Wow. What a beauty. I have a 1920's Logan lathe in my garage (same size). Dad has a 12" Southbend with a 6' bed that appears to be the same vintage. I am a huge fan of antique machinery.
My Logan has a built in cover/tensioner over the belt and back gears. It may be a good idea from a safety perspective to cover the belt and back-gears as there is a reason that modern lathes have these gaurds. Oh, used cookie sheets make excellent chip-pans. |
![]() I am planning on adding some guards before I let my teammates start using it. I rather everyone keeps their figures. ![]() |
Awesome. I didn't notice the cookie sheet before, but see it once you pointed it out.
These old lathes can be wonderful machines. I made 6" internal bearing lands for a sports racer a friend and I built. I also cu through 4" of steel for the spool drive. With practise and a good Machinist Handbook (if you don't have one buy one), you will be able to do amazing things. I did update my Logan with a quick release tool changer. This is a significant time saver as the Southbend/Logan 1/2 moon adjuster must be re-aligned every time you change operations. I found a set somewhere for about $250 that had the head unit and 4 tool holders (1 parting tool, 2 turning/facing, and 1 knurler). I kept the old unit, but have not used it since. Here is the Harbor Freight link. I don't think I bought the Harbor Freight unit, but something very similar. http://www.harborfreight.com/cpi/cta...emnumber=34816 |
Well, not me. Ha. Did find an American Scientific pocket guide from 1920 that uses a South Bend to illustrate the functions and implementations of a lathe though, good enough for me. ![]() |
#7
hahahahaha i just finished reading that book. it is really good and i recommend it to anyone who is learning how to use a lathe.
#8
Wish they made one for the mill.
#9
nice i have one but mine a bit older mine ped-metal lathe so you had to pedal it as you worked
i can't see how people could do it it hard to stay balanced as your work |
#10
![]() All freshmen labor jokes aside, it would be very hard to pedal while you machined. -Vivek |
#11
This one has 1/4 hp of pure custom built power. It runs very well for how old it is. Just motor hum, gear clicking, and belt nose only thing I could careless for is backlash, but I have seen worse on much newer. |
#12
Lucky you! That is a fine looking machine.
I see you are from NJ - too bad Henry Ford moved a chunk of Menlo Park and brought it here to Detroit (Dearborn). Because you can see a lot of the early machine tools there. So fun to look at, and not much has changed from the early days of machining. (OK, CNC is a nice add....) |
#13
Hi All,
this looks like memory lane to me.....it' the same as the machine I learned on years ago. Try Enco or CDCO for your quick change tool holder set (about $90) CDCO has the best deal on economy chucks Books: web search for "American machine tool" they have a nice Free downloadable packit on both lathe and the mill operation also the Home shop machinest is a good starter book, Great project, Have Fun! Geo. |
#14
I will probably pick up one of the machinist hand books off amazon for cheap. Hey it cut 1/4" 28 tpi just fine for me a minute ago. ![]() Also I be uploading a WAI in front of our Bridgeport which I also rebuilt (theres a story behind that one). Last edited by Lowfategg : 04-12-2008 at 16:45. |
#15
Hi low,
When you say "Lantern style" are you talking about a rocker tool post? (sometimes there is an east coast / left coast gap in terminology) the advantage to quick change is that you can set up multiple turning or form tools and switch out with out resetting center hight or when coupled with a DRO using tool offsets and maintain a true position (Shooting Star makes an affordable DRO, but the best is Newall) Geo. |
| [FTC]: Team Overdrive's robots close up photos | Lowfategg | FIRST Tech Challenge | 0 | 26-07-2008 23:05 |
| [FTC]: Team Overdrive's New Video | Lowfategg | FIRST Tech Challenge | 1 | 15-06-2008 20:17 |
| pic: Team Overdrive's #74 robot | Lowfategg | Extra Discussion | 9 | 06-03-2008 16:53 |
| pic: Arefin playing with my toys | Tytus Gerrish | Extra Discussion | 13 | 09-10-2005 23:28 |
