Go to Post It truly is a Merry Vexmas! - Ginger Power [more]
Unread 03-12-2008, 16:52
AdamHeard's Avatar
Lead Mentor
KingKrab
Team 973 presents our offseason prototype; King Krab.
-4 Wheel Crab Drive, opposite pairs of wheels driven and steered (AB and CD driven, AD and BC steered).
-Powered by 4 CIMs through AM Shifter Guts, 6/16 fps and traction limited in low.
-Steered by dual globes.
-4" diameter 1.5" Wide wheels with nitrile roughtop.
-Bevel gears and absolute encoders allowed unlimited module rotation with the same sensor reading for actual wheel angle.
-Currently would be 54 pounds with no electronics, but an electronics board. By switching to some aluminum and lightened hubbed sprockets, and turning down the bevel gears we believe we can save another 1.5 pounds.
-#10 bolt holes on a 1/2" hole pattern along the entire frame allows the gearboxes to be mounted anyway to work around manipulators. Also came to be very convenient for mounting items. We now have a jig with drill bushings to easily and accurately do it on a drill press.
-All chains are tensioned by a bearing block pulled by a bolt (similar to how some west coast drives have been tensioned), this also houses the sensor for each chain loop.
-Module itself rotates in a 1" bronze bushing and two 1/16" bronze thrust bearings, all other rotation is with ball bearings.
Thanks for any comments and feedback.
EDIT:
Frame Pic
Module Pic
Unread 03-12-2008, 17:09
Aren_Hill's Avatar
Build Nifty Things
Re: KingKrab
Awesome!
now drive it for the rest of the offseason nonstop, and you might be ready.
The most important thing we had to figure out with ours was making sure the drive knew how the thing would react to inputs, such as which route the wheels would take.
it reminds me very much of ours...lol but two sets of steered too
A guy who likes robots.
Unread 03-12-2008, 17:10
CraigHickman
Posts: n/a
Re: KingKrab
AWESOME.
Being the curious critter that I am, care to answer a few questions?
-Weight?
-Height?
-Module weight?
-Have any other closeups that I can ogle?
Unread 03-12-2008, 17:25
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: KingKrab
This is an awesome drivetrain so far. I too would love to see some detail shots of the modules and the entire thing both to admire and to be able to give you advice on improvements.
Mentor 2415
Unread 03-12-2008, 20:26
AdamHeard's Avatar
Lead Mentor
Re: KingKrab
An overall isometric view and a module view have been uploaded to CD-media.
The main improvement we would make for future iterations is custom cutting sprockets, turning down the bevel gears to save weight, switching to hex shafts (they are currently 3/8" 7075 with 1/8" keyway, wheel sits on a 3/8" 7075 dead axle), adding a second steering chain "tensioner" between the two modules on the outer edge to align the two modules angularly (they are just so slightly out of alignment) and add an adjustable rubber pad to add friction to the steering chain to ease the control loops tuning.
Also, we'd probably switch to heavily pocketed aluminum gearbox plates rather than the delrin. So far the flex has been minimal and hasn't caused any issues (although I suspect the compression from it makes the gearbox slightly less efficient), but I'm concerned of how it will change over time.
Unread 04-12-2008, 00:02
AKA: Sean
Re: KingKrab
Could you give me the part number of the bevel gears and where you purchased them? Also could you post more pictures of the individual module.
Mentor 2415
Unread 04-12-2008, 00:05
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: KingKrab
It's a great design that you guys have come up with, I'm glad to see you finally got it running! I especially like the configuration of your swerve drive, with the two driven pairs being different from the steered pairs. You should be able to make it do some pretty awesome maneuvers.
Now you just gotta figure out how to make it get up a step, and it will be perfect for this coming game!
Unread 04-12-2008, 00:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: KingKrab
No problem
2001-2004: Team 100
2006-Present: Team 254
Unread 04-12-2008, 01:45
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: KingKrab
Neato Design. I've always been fascinated by oddball drive systems like crab... looks like a very slick implementation.
But... am I just crazy, or is there no way for this drivetrain to spin in place without skid-steering?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 04-12-2008, 01:48
AKA: Sean
Re: KingKrab
-q
There are very few crab/swerve designs in FIRST that can spin in place without skid-steering. The only way to do it really is to chain the wheels in an X pattern, which is slightly more difficult than the traditional row orientation.
Mentor 2415
Unread 04-12-2008, 02:28
AdamHeard's Avatar
Lead Mentor
Re: KingKrab
Thanks for the kind words everyone, it really means a lot to us.
Craig, The module is 1.9 pounds as is. A 1" wheel significantly reduces the weight on top of that. The module was originally 1.1 pounds, but switching to 1.5" wheels, larger bevel gears and increasing the sideplates material all boosted it up a lot. I'm not sure, but between replacing the steel sprocket and turning down the bevel gears (they have BEEFY hubs) we can save a good deal there. The wheel could also be made a bit lighter, as it is currently .43 lbs for a 1.5".
The top of the 1x1 is 7.7ish inches, the entire frame is 6" tall (4" between levels) and we have 1.7ish inches of ground clearance. The frame itself could probably be made lighter, as it is all 1x1x1/8" except for the 4 inner cross members on the top (and the 4 short pieces of 2x1) and weighs 15.3 lbs + welds. It's currently not amazing at climbing ramps, but we drew some varied lower levels that should allow it to climb great. The nice part about this style module design is almost the entire front and rear face of the wheel is open assuming there is no frame blocking it.
I didn't mention before, but with the standard #10 pattern and the fact that the distance between inner and outer frame members is a constant 5", not only can gearboxes be slid up and down a side like I said before, but we can swap the locations of drive and steering gearboxes.
sdcantrell56, I'll tell you we used 12DP miter gears, but won't tell what tooth count or part number. I'm not trying to be secretive, but everyone I talked to about them warned me how important it is to make sure they are strong enough. We did a lot of calculations for it (only possible with the help of some great people) and still aren't sure they're strong enough, as we haven't started full speed, full weight, robot to robot interaction. As you know, the wheel size, tread, gearing, robot weight, etc. all effect the load on it, so you can't really say "it worked for 973.... it'll work for YYY".
What kind of views would you like of the module? The posted pic shows pretty much all it's features.
-q
The way "opposite" pairs are steered/driven it is only skid steer.
However, A difference in drive speed also causes the robot to spin unless the wheels are exactly aligned at 0 or 180 degrees (which is 90 degrees off from our skid-steer zone)
We have ideas that make this not really an issue, one is to implement "drift" buttons that slow or kill one pair of drive motors on a curve to cause the robot to spin on center while driving (credit to 1625). We imagine most rotating will be done by this, or by a 2nd stick at the point of scoring. We're working on implementing anglular presets with a gyro as well. I imagine we may try some gyro based turning while driving based on differing drive speeds.
Eh, didn't entirely answer your question, but that's our current gameplan for rotation.
Unread 04-12-2008, 03:08
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: KingKrab
Finally, after my summer hibernation, I have returned back to this world.... Adam, a "King Krab" is a crab in which each wheel is independently steered.
Pavan Davé
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 04-12-2008, 03:24
AdamHeard's Avatar
Lead Mentor
Re: KingKrab
Pavan Davé
It's just a name Pavan, keep it up and I'll confiscate that thingie over the e.
Unread 04-12-2008, 11:30
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Re: KingKrab
Originally Posted by Cory View Post
i absolutely love that robot
(still looking for videos of it, if anybody happens to have any)
adam,
looks really solid so far....keep posting videos of your progress on the control aspect.
-brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-12-2008, 12:04
AKA: Sean
Re: KingKrab
Ok so as a follow up question. Could you outline how you did the calculations to find out what gears would work? Also where did you purchase the miter gears?
Mentor 2415
