Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Unread 04-12-2008, 15:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: New Speed Controller Announced
Originally Posted by billbo911 View Post
The limit switch input for the Jag are normally closed. So, it would be possible to build a simple LED driver board that would turn on an LED if it saw the ground go away.
This, of course, is subject to the rules.
It occurs to me that you could use the NO side of the micro switch to drive your LED to the ground of the Jaguar. You'd want to grab your source voltage from some safe 5V supply, possibly on the Jag itself. Though this only tells you the position of your limit switch, not necessarily what the Jag is reading.
Reading the actual pin on the Jag would be trickier, as you'd need to make very certain you're no accidentally pulling the input high or low with your circuit.
New Vex Microcontroller announced Brandon Martus General Forum 19 07-05-2009 16:00
FRC Robot Controller/Speed Controller RoarRoar Control System 3 17-01-2008 10:41
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
New Special Edition GameBoy Announced Joe Matt Chit-Chat 12 13-01-2003 21:35
