Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 9 votes, 4.67 average. Display Modes
  #31   Spotlight this post!
Unread 04-12-2008, 15:54
REVving up for a new season
FRC #2848 (All-sparks)
Re: Game Hint #1
color modified, some of the words are readable. I could probably change the levels a bit more to get it better. Also I flipped it horizontally because the text would be backwards on the other side of the page.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
  #32   Spotlight this post!
Unread 04-12-2008, 15:55
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Game Hint #1
What filter levels did you use?
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #33   Spotlight this post!
Unread 04-12-2008, 15:56
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Game Hint #1
CONNECT THE DOTS!! Dots 1-3000 create a rough image of Dean Kamen.
  #34   Spotlight this post!
Unread 04-12-2008, 15:57
Michael Hill's Avatar
Re: Game Hint #1
It's a shop. I can tell from the pixels and the...metadata.
Also, checking out the file deeper, there seems to be some interesting embedded XML data. I don't know if this is common with Photoshop on OSX, but here it is anyway.
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>com.apple.print.PageFormat.PMHorizontalRes</key>
	<dict>
		<key>com.apple.print.ticket.creator</key>
		<string>com.apple.jobticket</string>
		<key>com.apple.print.ticket.itemArray</key>
		<array>
			<dict>
				<real>72</real>
				<key>com.apple.print.ticket.stateFlag</key>
				<integer>0</integer>
			</dict>
		</array>
	</dict>
	<key>com.apple.print.PageFormat.PMOrientation</key>
	<dict>
		<array>
			<dict>
				<integer>1</integer>
			</dict>
		</array>
	</dict>
	<key>com.apple.print.PageFormat.PMScaling</key>
	<dict>
		<array>
			<dict>
				<real>1</real>
			</dict>
		</array>
	</dict>
	<key>com.apple.print.PageFormat.PMVerticalRes</key>
	<dict>
		<array>
			<dict>
				<real>72</real>
			</dict>
		</array>
	</dict>
	<key>com.apple.print.PageFormat.PMVerticalScaling</key>
	<dict>
		<array>
			<dict>
				<real>1</real>
			</dict>
		</array>
	</dict>
	<key>com.apple.print.subTicket.paper_info_ticket</key>
	<dict>
		<key>PMPPDPaperCodeName</key>
		<dict>
			<array>
				<dict>
					<string>Letter</string>
				</dict>
			</array>
		</dict>
		<key>PMTiogaPaperName</key>
		<dict>
			<array>
				<dict>
					<string>na-letter</string>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.PageFormat.PMAdjustedPageRect</key>
		<dict>
			<array>
				<dict>
					<array>
						<real>0.0</real>
						<real>0.0</real>
						<real>734</real>
						<real>576</real>
					</array>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.PageFormat.PMAdjustedPaperRect</key>
		<dict>
			<array>
				<dict>
					<array>
						<real>-18</real>
						<real>-18</real>
						<real>774</real>
						<real>594</real>
					</array>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.PaperInfo.PMPaperName</key>
		<dict>
			<array>
				<dict>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.PaperInfo.PMUnadjustedPageRect</key>
		<dict>
			<array>
				<dict>
					<array>
						<real>0.0</real>
						<real>0.0</real>
						<real>734</real>
						<real>576</real>
					</array>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.PaperInfo.PMUnadjustedPaperRect</key>
		<dict>
			<array>
				<dict>
					<array>
						<real>-18</real>
						<real>-18</real>
						<real>774</real>
						<real>594</real>
					</array>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.PaperInfo.ppd.PMPaperName</key>
		<dict>
			<array>
				<dict>
					<string>US Letter</string>
				</dict>
			</array>
		</dict>
		<key>com.apple.print.ticket.APIVersion</key>
		<string>00.20</string>
		<key>com.apple.print.ticket.type</key>
		<string>com.apple.print.PaperInfoTicket</string>
	</dict>
	<string>com.apple.print.PageFormatTicket</string>
</dict>
</plist>
  #35   Spotlight this post!
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud oflenny8 has much to be proud of
Re: Game Hint #1
in the back ground you can see man ray lurking in the shadows
Learn something, Know Something, Do something
  #36   Spotlight this post!
Unread 04-12-2008, 15:59
The_M01e's Avatar
The_M01e The_M01e is offline
FRC #0964
The_M01e is an unknown quantity at this point
Re: Game Hint #1
Its Inner tubes(fish->water) fitting into small/thin places(fish->size)!
  #37   Spotlight this post!
ttldomination's Avatar
Sunny
Re: Game Hint #1
I doubt the actual hint is the fish. I think it may have more to do with the page in the background. If they really wanted to make the Opah the clue, then they would have simply copy and pasted a picture. .
Just something interesting though " An opah has four types of flesh, each a different color"
1648: 2013-2014
5283: 2015
  #38   Spotlight this post!
Unread 04-12-2008, 16:03
The_M01e's Avatar
FRC #0964
Re: Game Hint #1
i found something.
http://www.absoluteastronomy.com/topics/Lancetfish
You can get some of the words out of it in the correct order.
  #39   Spotlight this post!
synth3tk's Avatar
AKA: David Thomas
Re: Game Hint #1
The_M01e just found a website containing the exact background text:
  #40   Spotlight this post!
Unread 04-12-2008, 16:05
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Game Hint #1
The fish is shaped like a football. Footballs, or rugby balls, will be used as game pieces.
Richard Wallace
since 2003
  #41   Spotlight this post!
Unread 04-12-2008, 16:06
The_M01e's Avatar
FRC #0964
Re: Game Hint #1
Me again, I think morphology is what we're looking for on the website. I think thats the big hint.
  #42   Spotlight this post!
Unread 04-12-2008, 16:07
SamC SamC is offline
AKA: Sam Couch
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Re: Game Hint #1
..and the FIRST/CD community has successfully crashed another site today...
  #43   Spotlight this post!
Unread 04-12-2008, 16:08
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Re: Game Hint #1
I doubt they scanned it... found this image here:
http://www.australianseafoodexports..../moonfish1.jpg
http://www.australianseafoodexports....rderonline.htm
Google Images: "Moon Fish"
Enjoy!
-Oris-
  #44   Spotlight this post!
Unread 04-12-2008, 16:09
Sunny
Re: Game Hint #1
This has got to be the fastest growing thread yet. But, I think the rugby/football idea might be it....
1648: 2013-2014
5283: 2015
  #45   Spotlight this post!
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Game Hint #1
I'm going to call that this is conclusive proof that this year there will NOT be a water game. Dave would never be that obvious...
Game hint #3 garyk General Forum 7 02-01-2008 16:54
Game Hint Tally T3_1565 Rumor Mill 137 29-12-2007 23:11
pic: Game hint Joe Ross Extra Discussion 625 22-12-2007 20:24
Offical Game Hint! Greg Needel Rumor Mill 117 21-12-2006 16:25
Game hint?!?! Andy Grady Rumor Mill 67 30-12-2002 18:15
