Go to Post Kids should already be motivated to build the best robot they can, and learn as much as they can. They shouldn't need extra incentives. - Matt382 [more]
Unread 04-12-2008, 16:52
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
Controller help
I currently am working on a benchtop test however the vic and jag are not getting a siginal from the sidecar. the three led's are lit up on the sidecar. any ideas?
Thanks
Matt
Team 894 Chargers Robotics
Unread 04-12-2008, 17:14
Re: Controller help
Might I suggest http://forums.usfirst.org/forumdisplay.php?f=743, also known as the Beta Test forum? I would guess that someone has found this before and asked about it.
Unread 04-12-2008, 21:28
merybar's Avatar
AKA: Matt
Re: Controller help
thanks for your help, i figured it out with the help of a mentor, was in a bind and wanted some quick advice....
Unread 04-12-2008, 22:48
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Controller help
Can you explain what you did? Our team is having the same problems.
Unread 04-12-2008, 23:02
merybar's Avatar
AKA: Matt
Re: Controller help
I was plugging the PWM cables into the wrong side of the sidecar. They are supposed to go on the side with the white pieces of plastic separating them from each other. Make sure that it is plugged into the three prong part and i believe white facing out? Try both ways though. Sorry this isnt more specific im horrible at technical terms unless its sitting in front of me. Let me know if you need more help
Matt
Unread 04-12-2008, 23:12
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: Controller help
Matt
Make sure you don't plug the PWM's in backwards, as you may damage something. Remember, GND is black.
According to the Component Datasheet (http://www.usfirst.org/uploadedFiles...-Rev-0-5a.pdf), the black should face the outside of the sidecar.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 04-12-2008, 23:32
Cecil's Avatar
AKA: Alex Hummel
Re: Controller help
ok, we will try this Tuesday when we meet. I know we did plug them into the connectors under the blue tab. Thank you.
I'm right 90% of the time, so why worry about the other 3%?
Unread 05-12-2008, 14:53
merybar's Avatar
AKA: Matt
Re: Controller help
Thats exactly what i did first. Should work for you now!!!!!
Unread 09-12-2008, 21:36
Cecil's Avatar
AKA: Alex Hummel
Re: Controller help
Thank you, this worked.
Controller Viewing help? GrammarNazi Rules/Strategy 2 13-02-2008 18:09
Controller help!!!! team877 Programming 3 10-01-2008 19:34
EduBot Help, RC Controller Allison K Robotics Education and Curriculum 5 29-03-2004 16:48
Help - Gear Motor Controller dteshome Motors 17 13-05-2003 15:13
Need help with controller Devil's Kid Technical Discussion 6 20-01-2002 21:47
