Re: inconsistent wireless code downloading
So I did some testing and here is what I found. I'm using windriver and C++. If I use the debug method of running code on the robot through the RAM everything works fine however if I download the code and reboot the robot the two modes (teleop and autonomous) dont change until the robot is not in their mode. I did a really simple test (switching joysticks in teleop) and found that if i reboot the robot in teleoperated mode the joysticks wern't switched but i switched to autonomous and back it worked. the same thing happened with autonomous. any ideas whats up?
| Problem downloading code | Romeo1351 | FIRST Tech Challenge | 6 | 01-12-2006 06:33 |
| Downloading code to 2005 RC | Eclipse | Control System | 2 | 23-02-2006 19:58 |
| Code error on RC after downloading "bells and whistles" version of Kevins camera code | DanDon | Programming | 6 | 10-01-2006 18:07 |
| Problem downloading any Camera code | zuckie13 | Programming | 4 | 07-02-2005 20:32 |
| Downloading Code with new Editor | gburlison | Programming | 4 | 17-01-2003 01:10 |
