Go to Post We only ask that, when able, you too help other teams as we have helped you. It is this mentality of passing it forward that makes teams and FIRST great. - E. Wood [more]
Unread 03-12-2008, 22:16
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Question "West Coast" drive?
I've heard references to "West Coast"-style drivetrains a few times now on CD, and am puzzled as to what that means.
The only real information I've been able to dig up is:
Originally Posted by lukevanoort
Unless you are mounting your wheels directly on the transmission output shaft (West Coast Drive style)
Is that it, or does a West Coast drive entail more than that?
Also, what are the performance implications (positive or negative) of the use of such a drivetrain?
Unread 03-12-2008, 22:21
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: "West Coast" drive?
I've also heard of this, but cannot define it for you exactly as there is no real definition for it.
I believe it just means they have a shaft driving the wheels directly from the transmission instead of running wheels from a chain and sprocket without any real physical connection to the wheel. There are obvious advantages, as a live axle wheel has little to no chance of losing power. If all your chains fall off, the robot will likely still have mobility. It also can reduce weight since you eliminate chain and sprockets.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 03-12-2008, 22:22
6WD, drop center wheel directly driven from the gearbox. A modified version is to do a chain to the center as well as the rest.
6WD "drop" drive has a pile of implications that are out here.
Unread 03-12-2008, 22:24
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
It also seems to me that west coast drives don't have outer chassis rails with bearing supports.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 03-12-2008, 22:26
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
"West Coast" is used to refer to drive bases, most commonly 6wd, that have the wheels cantilevered outside the frame, usually with live axles and the center wheel directly driven by the transmission output shaft. The term is loosely used, but a definitive example of a west coast drive would be those built by team 254 or team 60. There are several advantages to a west coast drive system, mainly ease of maintenance and the light weight. Possible drawbacks include dangers to the wheels, which can be negated with bumper use or some sort of wheel guards, and manufacturing difficulties, which vary with your abilities and experience.
Unread 03-12-2008, 22:29
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Direct center wheel power, live axles, 6WD drop center, cantilevered shafts, and wheel slide tensioners are all generally bundled into the term "West Coast Drive"
A classic example is the drivetrains of 254 and 968
http://www.chiefdelphi.com/media/photos/25814
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
GUI nailed it.
254 can hardly take credit for the design though. It was Glenn Thoroughman's (60) baby from the start. We may have popularized it over the years (along with 968 and others), but Glenn should get all credit for the original design.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-12-2008, 23:31
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
West Coast Style
The Universal Chassis is a "West Coast Style" clone. Thanks to all those teams that helped perfect this gold standard of FIRST.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 04-12-2008, 00:56
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
But really, any "West Coast" style drivetrain might as well be named "(Team # Who Built It) Coast" because it has not only spread in popularity, but in variations of the design. I know my design (pictured above) has been tagged "West Coast" but it still lacks direct center wheel power, multi-motor transmissions, and wheel slide tensioners.
Unread 04-12-2008, 01:30
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I just saw that you are from Duluth High School. I am a mentor at North Gwinnett. It's good to see you on here.
As has already been said, "west coast" has taken on many meanings, but it seems to have become synonymous with wheels cantilevered outside of the frame. Teams have designed many different variations of it with sliding tensioners, live and dead axles, directly driven center wheels, and many other variations.
The main performance benefits are slightly increased stability due to a larger track width, and much quicker wheel/tread changes.
The downside is that the wheels are unprotected, and many versions such as the awesome 254/968 iteration are very machining intensive.
If you guys need any help with drivetrains just send me a pm or something and I'd be glad to share with you the designs I've been working on and our previous drivetrain.
Mentor 2415
Unread 04-12-2008, 18:59
AdamHeard's Avatar
Lead Mentor
I would say that being machining intensive is not a downside of a West Coast Drive. Sure, a super efficient and lightweight design can be made with all custom parts, but you can also do a decent west coast without. Last year on 973, we just machined the siderails, two bearing blocks per side (just a block the size of the inner portion of the extrusion), the wheel shafts and the wheels. With COTs gearboxes and wheels, minimal machining is required. If your team can't get enough machining resources to get that made, your team is just not trying at all.
Unread 04-12-2008, 21:35
AKA: Sean
I was simply saying that a lot of the machining necessary for a west coast drivetrain requires at least a mill, and a cnc mill would be even better. I do agree with you that any team should be able to ask around and find someone willing to machine a few parts for them. A lot of companies are very eager to help with FIRST since the robots are a lot "cooler" than the parts they normally make. One of the things I have been doing is trying to design a west coast drive that i feel will be reliable and easy enough to make using mostly sheet metal tools since our main sponsor is a sheet metal shop. There are many different ways to do a "west coast" drivetrain and it's really up to the team to decide how much machining they put into it.
Mentor 2415
Unread 04-12-2008, 23:12
GUI GUI is offline
AKA: Gary
It is actually quite possible to build a west coast style drive system without anything beyond basic sawing and drilling. Our design last year could easily be converted to use live axles and direct drive on the center wheel by using commercially available pillowblocks and AM supershifters. Granted, certain parts would preferrably be different or customized slightly, but it would be reliable, easy, and cheap.
Unread 04-12-2008, 23:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Time to get that wood OS chassis design started...it could be a "poor team's west coast drive", in one of the many possible variations.
Unread 04-12-2008, 23:22
AKA: Sean
I have actually been working on a couple different wooden west coast designs although I don't know if I'd say they would be easy to do without a cnc mill or laser, or really just a mill. Of course it could be adapted to work with just a drill although it certainly wouldn't be as robust.
Mentor 2415
Where Are "Chassis & Drive Train Instructions" Robeaux Kit & Additional Hardware 1 10-01-2006 16:17
Where Are "Chassis & Drive Train Instructions" Robeaux Technical Discussion 1 10-01-2006 16:17
West Coast "KRUNCH Time" Fll Tournment Tytus Gerrish FIRST Lego League 0 12-12-2003 10:27
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
