Re: cRIO - motor controller code (esp. victor)
I was just looking at the specs and manual (found via google search at
http://www.ifirobotics.com/victor-88...r-robots.shtml and http://www.ifirobotics.com/docs/ifi-...al-9-25-06.pdf) The spec sheet states that the dead band is centered around 127. The manual describes the calibration process. I would expect the defaults in the code to match the specs, not some empirical test (with out a lot of explanation as to why the specs are wrong and must be overridden by default). |
| Motor to Victor | jumpe1990 | Motors | 11 | 20-02-2008 09:34 |
| Window Motor on a Victor? | DavidGitz | Kit & Additional Hardware | 1 | 13-01-2007 09:42 |
| Non-Victor Speed Controller | FourPenguins | Electrical | 6 | 31-10-2006 15:46 |
| What Victor for VEX Controller? | Chris_Elston | Electrical | 5 | 25-04-2006 21:00 |
| Victor controller problem | llambele | Technical Discussion | 3 | 14-11-2001 23:00 |
