Go to Post Could you post your code? It is hard to debug that which you cannot see... - Dusk Star [more]
Unread 02-12-2008, 17:22
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
Mounting 2009 Controller and Components
We just received the prelim kit of parts including the 2009 controller and associated components. The bench test directions specify the mounting of all the components on a peice of plywood or plastic. Is this really necessary. Can it be mounted on a sheet of aluminum instead? We want to mount the components in a sheet alumimun chassis that can be removed from the robot as a single unit to be tested on the bench. Are there rules stating that the controller components must be mounted on a nonconductive base?
Unread 02-12-2008, 17:25
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Mounting 2009 Controller and Components
The cRIO has a grounded enclosure. The 2009 rules are not out yet, so no one can say whether it would actually be permitted or not for the competition. Regardless, mounting it on a conductive surface would be a REALLY BAD idea.
-dave
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
You can mount the electronics to aluminum. For protoype purposes and bench top testing wood is just less expensive and faster to work with.
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 02-12-2008, 17:35
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
We can't know for sure whether it will be a rule or not until kickoff.
However, this kind of rule is a rule for a reason: Its a good idea to have electronics mounted on a non-conductive surface for saftey reasons.
Unread 02-12-2008, 17:52
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I had heard about the cRIO having a grounded enclosure, but, oddly enough, neither I nor a bunch of other people were able to find continuity between any part of the cRIO's chassis and the robot's ground, on Team 1114's beta-test robot. Some people I talked to theorized that this could have something to do with the 12V to 24V conversion circuit - can anyone shed some light on this?
In any case, 1114 had the cRIO mounted (using Velcro), without incident, to an aluminium sheet along with the rest of the control system. It's feasible, but, as Dave indicated, its legality has yet to be disclosed.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 02-12-2008, 22:08
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by dlavery View Post
The cRIO has a grounded enclosure. .....mounting it on a conductive surface would be a REALLY BAD idea.
Perhaps mounting this to a conductive surface being a bad idea has more to do with electricity than the 2008 rules.
Static electricity impulses are bad for electronics, especially those that come with those yellow static warning labels on them - so touching any part of the metal mounting surface will conduct those pulses into your device - possibly with bad results.
Dynamic electricity (the counterpart to static, I think) flows along conductive surfaces, and if one of those big red cables happens to wear or get cut through, there may be some excitement - and that's meant in a bad way.
I can speculate on the 2009 rules, and electrical components will likely have to be isolated from the robot chassis, so you'd have to get rid f the aluminum anyway...so use the plywood for now and get the lexan for the production 'bot.
Don
Unread 02-12-2008, 23:03
minisimon's Avatar
minisimon minisimon is offline
AKA: Simon Helmore
FRC #0238
minisimon will become famous soon enoughminisimon will become famous soon enough
It's also worth noting that if your chassis is grounded through the cRIO, then any short through the chassis also runs through the cRIO. This might be bad.
With regard to the lack of continuity between ground and the chassis even when the cRIO is mounted to aluminum: could it be because of the paint?
Unread 03-12-2008, 10:29
I can't speak for the 2009 Rules, look to the GDC for that.
What I can say is that regardless of the rules, please do not mount your cRIO or your Camera to a conductive surface. Both have grounded cases, which could provide an unfortunate current path.
I believe the cRIO's coating is non-conductive (NI, could you chime in here?), but I personally would not rely on that. The PD does have a small self-healing PTC in the cRIO's ground return path, so you shouldn't be able to do damage to it. However, it avoids damage by breaking the circuit, which will shut down your robot and possibly create a "match deciding failure".
In either case, connecting your cRIO or Camera to the chassis increases the likelihood of a bad chassis fault. In a properly wired system, two errors must happen before you short your battery through the frame - a positive AND a negative wire must hit the frame. If you don't isolate the cRIO or Camera, only a single positive wire must hit the frame to cause Badness 10k.
Unread 03-12-2008, 11:32
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Addendum to Eric's comments -
The PTC in the ground return path for the cRIO's power supply will limit any chassis shorts that are conducted through the cRIO to an amp or 2. Definitely annoying and match-ending but safe.
There is no equivalent protection for shorts to the camera's chassis. I'm not at liberty to speak for the GDC but I'd be very surprised if using a conductive mouting for the camera will be allowed.
The above issues bring up a very important inspection task - WHEN you test for chassis shorts before shipping your robot (wink wink nudge nudge), you WILL detect a chassis short if your cRIO is attached to a conductive surface and bypasses any non-conductive coatings. You WILL detect a chassis short if you conductively-mount your camera. PLEASE fix the camera mounting issue before shipping your robot. Depending on the robot rules, if conductive mounting of the cRIO is allowed, you'll need to disconnect the power cable to cRIO when testing for shorted chassis.
Russ
Unread 03-12-2008, 11:38
Conductive mounting of the cRIO is not allowed for any teams I mentor.
Unread 06-12-2008, 22:48
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Mounting the cRIO
Besides putting Velcro on the back of the cRIO, has anyone come up with a secure way to mount the cRIO to a control board? It only has theaded holes on one end. I guess Velcro has the benefit of making it possible to quickly change the cRIO from one robot to another but it seems like there should be a better way.
Unread 06-12-2008, 22:49
AdamHeard's Avatar
Lead Mentor
Re: Mounting the cRIO
There are 3 clearance holes in the bottom, the modules may be obstructing the view.
Programming with the 2009 controller slavik262 Programming 97 20-10-2008 21:59
pic: 2009 Speed Controller by Luminary Micro Greg Needel Extra Discussion 26 10-08-2008 22:26
Purchasing the 2009 controller Tottanka FRC Control System 60 04-05-2008 19:44
Pneumatics Board/Mounting Components ASmith1675 Pneumatics 2 06-02-2008 13:47
Question on mounting components BQuennell Electrical 7 31-01-2007 12:01
