Go to Post A challenge to those of you grumbling about the refereeing this year: Be a referee next year. - Alan Anderson [more]
Unread 07-12-2008, 09:00
Eric.DaddyOh Eric.DaddyOh is offline
Eric.DaddyOh is an unknown quantity at this point
Smile Re: [FTC]: Virginia Championship Results
What sort of information are you looking for about FTC at U VA?
I'm not sure who won? Please someone post that here. We left before the end of the final match. But the tournament was lots of fun. I was a field controller, so had a somewhat limited view of the action (but up close at the field).
The teams, mentors, coaches, volunteers and everyone was great. There were some amazing robotics and positive attitudes. Given that we were using a new platform, it seemed to go pretty well overall.
Some things I noted that other teams might want to consider for your tournaments:
1) Please charge your NXT batteries ahead of time and have spares that are charged. Maybe even has have some disposables just in case.
2) Please take you battery our of the nxt for at least 30 seconds PRIOR to coming to the field controllers table.
3) Don't change your batteries after registering at the field controllers station for that match. If you do you will have to re-register the nxt.
4) Registration of the nxt bluetooth with the field management system was at times problematic and slowed us down much before we figured some work arounds.
5) There were a few times that bluetooth connections were lost during a match. If you suspect that has occurred, ask the field controller to look at the Field Management System screen and see which teams were disconnected. It is up to the tournament organizers and chief referee to decide if any matches are rerun because of this. We have limited data around cause and effect. Your NXT program can be problematic, interference in the building can be and as well the field management system can be. We did manage to get through this and everyone kept a positive outlook for the most part on the problems associated with the new platform.
6) Early matches were plagued with teams not understanding how to set their NXT up for running the autonomous mode and the tele-operated mode via the field management system. I'm not an expert in this so if you are uncertain, please research this in advance and find out for your software platform how others are making this work successfully.
7) Get your robot inspected early before the matches begin.
8) Have fun, Its all a learning exercise.....
For Tournament Directors
1) You want field controller volunteers that understand the MS XP environment. We will be posting information somewhere about how to ensure timely connections to the bluetooth on the nxt using the field controller management system. I'll reply to this link when we have that information posted so you know where it is posted.
2) have a spare or two field controller system
3) Don't use the cheap USB cables provided with the field controller kits. Get one of those lighted USB cables (we have a bad USB port and the lights made diagnosing that a snap).
4) Set up an alternative robot inspection location outside of the match area for the teams that just couldn't make inspection in time.
Thanks to everyone for a great tournament.
Eric
[FTC]: 2008 FTC World Championship volunteers needed KathieK FIRST Tech Challenge 0 20-01-2008 21:54
[FTC]: FTC Championship results ManicMechanic FIRST Tech Challenge 1 12-01-2008 21:47
[FTC]: 07-08 Season VA FTC Championship gblake FIRST Tech Challenge 3 05-12-2007 10:52
Masachusetts FVC Championship results syraweb FIRST Tech Challenge 3 23-12-2006 23:13
FVC Florida Championship - Results Michael Coleman FIRST Tech Challenge 4 19-12-2006 23:50
