Go to Post The more time we spend there, and the more investment we have in the team, the more rewarding it is. - ILAMtitan [more]
Unread 07-12-2008, 18:14
AdamHeard's Avatar
Lead Mentor
Trouble updating firmware
When we attempt to update firmware, after it says "Hold select" and we hold select, it flashes a screen for a split second then goes back to the main screen.
Unread 07-12-2008, 18:31
Re: Trouble updating firmware
I think that happens when the DS cannot find the firmware update file "dsud_pkg.bin" on the top level of the memory stick.
Can be because the file name is incorrect or because it has trouble with the model memory stick.
Check your file name (no hidden extensions), then try a different model stick.
Unread 07-12-2008, 21:29
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I saw this the other day with someone else's driver station. The problem went away when I substituted my USB stick for his. Either it was the stick itself, or the fact that while his stick was full of other stuff, mine had only the firmware.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 07-12-2008, 22:16
AdamHeard's Avatar
Lead Mentor
Turns out the student had file extensions turned off, so they named it filename.bin.bin, rather than filename.bin.
Thanks for the fast responses though.
Unread 17-12-2008, 09:22
team1512's Avatar
team1512 team1512 is offline
FRC #1512
team1512 is an unknown quantity at this point
We had the same problem but we just switched drives and it worked.
updating firmware on crio nickmagus Programming 16 17-12-2008 16:58
RCX Firmware trouble sad6_lego_robot Lego Mindstorm Discussion 9 17-07-2008 15:36
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
Updating the paperwork? DinkyDogg 3D Animation and Competition 3 11-02-2006 21:09
