Go to Post Just as you and your team will make hard decisions as you struggle to build a robot, FIRST has had to make hard decisions concerning maximizing safety while making the number of rules as small as possible. - Mike Betts [more]
Go Back   Chief Delphi > Other > VEX
Unread 08-12-2008, 00:00
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Tank Track
These pictures - Compliments of Team 42 (Mostly Harmless) - might help out.
Tread Mounting Pic 1
Tread Mounting Pic 2
Tread Mounting Pic 3
The scenes in the photos are rather messy, but if you zoom in on the ends of the three devices and look at the flat sections/sides of them, you might find something you can use.
There aren't many ways to avoid using at least one sprocket, and there are precious few that are very useful; but there are a few tricks.
Good luck - See you in Dallas -Go Kiwis!
Blake
PS: Whether you win or lose on Saturday - Send us a picture!
Unread 08-12-2008, 01:46
Re: Tank Track
Forget the tank treads -- I see you use the same black boxes with yellow trays that we do. Good taste in parts bins, my friend.
Track Design Mrtrom General Forum 1 08-01-2008 23:05
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Track Drive greenz_gurl15 Technical Discussion 1 13-01-2003 23:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
