Go to Post What seems logical to you will seem strange to someone else. Never assume that someone else will do the logical thing. - Wetzel [more]
Go Back   Chief Delphi > Other > VEX
Unread 08-12-2008, 02:37
phr34kR's Avatar
phr34kR phr34kR is offline
AKA: electrical/mechanical/Pneumatics
no team (symbiOHSis)
phr34kR is an unknown quantity at this point
Send a message via MSN to phr34kR
Re: Tank Track
hi, the tank tread idea seems to be a good idea but in the competitions in NZ they don't seem to be working that well. I think for the idea to be reliable you would need to create some sort off suspension between the treads, i had an idea of using slotted plates and standoffs with rubber bands around them to create floating rollers that would let the treads expand to hold the cubes securely (i would like to prototype the idea but unfortunately my team doesn't have a set of treads yet). BTW i really liked your pneumatic claw set up, using steel cable and attaching the cylinder at the end of the arm, i thought it saved a lot of weight at the end of the arm where it counts good luck for Saturday and see you then.
YAY won 6 out of 8 New Zealand VEX competitions!(and only killed Three servos in the process)
at least we made the semis
Its not a hole its a controlled leak...
Winners of the New Zealand excellence award (yay going to Dallas)
Unread 08-12-2008, 23:24
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
Re: Tank Track
For a tank tread system to work effectively you should make sure that the tracks are tensioned correctly so that the tread doesn't sag.
Unread 09-12-2008, 12:41
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Re: Tank Track
Moving the treads apart slightly and using rubber bands or non-skid padding allows sufficient room for the cubes while maintaining grip that "gives."
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 20-12-2008, 04:30
SCROSSLEY-GCEC's Avatar
SCROSSLEY-GCEC SCROSSLEY-GCEC is offline
Number One Issue!! :D
SCROSSLEY-GCEC has a spectacular aura aboutSCROSSLEY-GCEC has a spectacular aura about
Send a message via MSN to SCROSSLEY-GCEC
Re: Tank Track
Hi Guys,
Competition was last Saturday.
We ended up redoing our design to go with the side tracks, because when we finally got the horizontal going it was too heavy for the 'bot to drive properly.
we made it to the semi's (i drove ) but then lost out when our alliance bot malfunctioned so the other alliance was faster than us oh well, we were so happy to make semi's - as did the other team from our school who played in the other semi and lost too.
Will put up photos tomorrow or the next day when i can (finally) get them from my teammate
If we make it to Dallas look us up
Unread 04-01-2009, 21:18
Re: Tank Track
2 weeks later:
received photos yesterday ^^;; real sorry guys
http://s84.photobucket.com/albums/k5/purpanie/Robotics/
phr34kR - we liked your banner
(ours: http://s84.photobucket.com/albums/k5...t=img_0327.jpg)
Unread 04-01-2009, 21:48
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Tank Track
Originally Posted by SCROSSLEY-GCEC View Post
... received photos yesterday ...
Thanks!
What's that odd-looking machine next to you on the field in picture 15?
Blake
Unread 05-01-2009, 21:26
Re: Tank Track
that was the 'bot made with partially non-VEX parts who were on our alliance. they had a cable-based elevator lift which worked to good effect when it wasn't breaking down
Unread 05-01-2009, 21:39
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: Tank Track
Non-Vex parts??? That is odd.
Here in the US we are only allowed to use Vex parts - Does being far away from IFI's warehouses mean the rules were relaxed for your tournament, or was it an "unofficial" tournament? or was something else going on?
Blake
Unread 05-01-2009, 23:09
phr34kR's Avatar
Re: Tank Track
hi, ATM we are just having non official competitions and you are allowed to modify anything you wist freely the electronics etc. you are also allowed to use not vex material. There will be official competitions in March? though to decide on the teams that go to America to compete. Saying that our VEX robot that was fully VEX came second while our other robot that includes some curtain rail and sheet aluminum was on the winning alliance. our team is trying to get our robots as close to fully VEX as we can ATM so come the official competitions we will have a trialed design.
-unfortunately our banner is no more (heavily taped and zip-tied) we will hopefully be getting a proper final one soon though
Unread 06-01-2009, 08:25
Re: Tank Track
Blake
as phr34kR said, ours aren't currently qualifying for champs.
its mostly the cost of importing parts from the U.S. i think, so to get us some practice - since this is the first year of VEX in New Zealand - they currently allowing non-VEX parts.
we had our pneumatic-claw robot (christened ricebot by me and some mates - long story) in one semi and our tank tread bot (Philup ) in the other, both with full VEX parts. oh, except for the flashing LEDs on the ricebot when one of the boys got bored, and the tinsel on Philup
of the eight bots in the semi's at least three were full VEX and i believe it was more like three that weren't
i think the next competition is March 9th - not sure if that counts for champs though
see you in the finals phr34kR? unfortunately i don't think i will be driving next time though as the seniors like to do everything themselves (*yr 10* )
awww that really sucks, we'll have ours there next competition. we're VERY proud of it haha
saw your buttons, too. they were cool we hope to have ours for next competition so might have to organize an exchange
Unread 06-01-2009, 10:19
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Tank Track
How many New Zealand teams are there?
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 06-01-2009, 14:27
phr34kR's Avatar
Re: Tank Track
I think there are around twenty something teams, not sure on the exact number but i am fairly sure there are under 30. Shipping is the major killer we order US$600 worth of parts which end up costing us around NZ$1000 add on top of that NZ$600 worth of shipping (if we ordered it ourselves luckily we can add our stuff in with the university that runs it) But it makes it almost impossible to order without pooling our orders together at least for our team and the limited funds we have. We do however have a very supportive school that will cover the costs while we fund raise.
Unread 06-01-2009, 18:44
Re: Tank Track
Depends how many each school enters general amount is about 28
you're really lucky. Our school gave us $2000 to cover all our VEX kits, button maker, spare parts, decorative stuff (banner etc) and everything else up until our FRC competition. it was gone at the beginning from three VEX kits plus disposable batteries >_>
everything currently is coming out of our Head Mentors pocket, which kinda sucks. we need to start fundraising too.
Unread 06-01-2009, 19:17
phr34kR's Avatar
Re: Tank Track
I should probably clear that up, i believe we have paid off all our debts but i think its cool how your school actually gave you some money, we have had to fund raise the entire thing. I'm glad we changed to the rechargeable's we went through $80 worth of batteries in a day of competition plus another $50 on practice for the competition.
Unread 08-01-2009, 07:00
Trueliez Trueliez is offline
self-proclaimed genius
AKA: Giselle
VRC #2918 (GCEC (Glenfield College Eccentric Cyborgs))
Team Role: Photography
Trueliez will become famous soon enoughTrueliez will become famous soon enough
Send a message via MSN to Trueliez
Re: Tank Track
Hi Guys,
we made it to the semi's (i drove) but then lost out when our alliance bot malfunctioned so the other alliance was faster than us oh well, we were so happy to make semi's - as did the other team from our school who played in the other semi and lost too.
Yes, that competition went really well. I was so thrilled to see Phillup get so far in it, especially after the trials of building him!
I never thought I would get into building chassis, but I guess that's one of the beauties of FIRST - steep learning curves.
I'm not sure whether I thought there was more or less variation in the designs of the 'bots between the competing teams this time round. I did notice however that there were less quirky experimental ones and more that worked consistently throughout the matches.
I miss the quirks, because it made it entertaining to watch, but I think it goes to show that the teams here are really starting to focus and hone skills.
Correction dear, when we get to Dalhas
2 weeks later:
Good to see my photography gets put to good use
Sorry about the delay on the photos, technical difficulties with the camera and it's cable.
And I agree, the banners at the competition looked fantastic
The $2000 was actually a grant from the local ASB branch which was sourced by our principal. Unfortunately it didn't even cover the three VEX kits. It bothers me that our Mentor is spending so much on our team, though I know it's his passion, and that's something I would really like to change this year.
Check out my artwork here
Track Design Mrtrom General Forum 1 08-01-2008 23:05
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Track Drive greenz_gurl15 Technical Discussion 1 13-01-2003 23:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
