Go to Post Joe is a great sport and this was a good moral booster after a grueling weekend. How many opportunities do you get to play William Tell with a Regional WFA Winner? :) - The Lucas [more]
Unread 08-12-2008, 08:56
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
pic: OH GOD! WHAT HAVE I DONE???
Unread 08-12-2008, 09:01
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: OH GOD! WHAT HAVE I DONE???
It really depends on where you have to pick up the game piece from, but I have an idea. For easier driver control, you could make the first arm coming off the large bottom sprocket a 4-bar linkage. Adds a bit of weight and slight complexity for mounting the next joint. Yet you essentially add another option in control the driver without having to add sensors, button, or more programming. This wouldn't work if you had to pick something up off the ground, unless you telescoped the arm out (tradeoff in complexity I guess).
At 70 inches long, we really couldn't make a suggest for the reduction until we see a game piece. For instance, this would be perfect for a 2007 tube using dual-FP's on the base, but for the 2008 trackball you'd want a high-torque CIM with some sort of braking mechanism.
GitHub
Unread 08-12-2008, 10:43
Aren_Hill's Avatar
Build Nifty Things
you've made quite a nifty arrangement of manipulation.
As a driver id be a little intimidated to operate that with any dexterity unless i just had a miniature of it on the OI then it would work fairly well.
idk if you'll be able to pull off 1 fp down at the bottom to move that thing it looks like its getting fairly hefty up top. Im probably wrong though FP's are beasts (our shooter this past year is proof).
this thing would be very impressive to see on a bot
A guy who likes robots.
Unread 08-12-2008, 11:10
Data Nerd
FRC #0079
I second the feeling that it is nifty.
As it stands right now I would write a series of equations that will give you the position in a 2d plane (aligned along the face of the large sprocket) and then work them backwards. These equations would be pretty scary to figure out but once you do them and solve them for x and y you can just use a series of buttons to control it. If you added on a turret you just have to know that that plane will rotate. In all honesty it actually isn't that hard to control. If your driver wanted to be able to control it he could just have a stick to tell it to increase the distance in the y direction or the x direction.
On an unrelated side note, roboticWanderor, your cads are impressive and an inspiration.
Unread 08-12-2008, 11:27
Aren_Hill's Avatar
Build Nifty Things
I'm just usually a stickler for the controls being very very intuitive
hence why in 2007 i built this
http://www.chiefdelphi.com/media/photos/29147
and i wasn't even the arm operator
I usually wanna know exactly what the robot is going to do when i give it an input, as any delays or mistakes can easily lose you a match
plus im a mechanical guy and a mechanical thinker so simple links between control movement and robot movement are a must for me.
Unread 08-12-2008, 11:36
Data Nerd
FRC #0079
Yeah, I am a programmer and as such have a genetic predisposition to distrust mechanical systems.
A physical model would be simpler to do. Perhaps a compromise would work best, a mechanical model which could be used to train some buttons, yet would allow you to fine tune on the fly. Might be an interesting way of controlling a system.
Unread 08-12-2008, 13:09
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
how are you driving the second joint? what is the gearbox on the end of the arm for? is it to drive the second joint or to extend the telescope? if not what drives the telescope?
295 Team Captain
Unread 08-12-2008, 13:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Loading depends on the center of mass of your arm, and how heavy an object you're trying to pick up. Gearing depends on the motor you're using, how fast you want it to go, and how often it will be moving.
If all 24 lbs of your arm is centered 40in off that pivot, you're talking about 960 in-lbs of torque. One CIM puts out about 25 in-lbs of torque at 40A. So you'd need at least 1:150 or so gear ratio, probably more, given the efficiencies you'd be getting at that ratio. Just for lifting the arm by itself. Four AndyMark StackerBoxes would get you to 1:160 or so, and you could reduce from there as necessary.
Also, this is for lifting the arm from dead flat, if it won't ever get there or you counter balance it, you could improve things.
Unread 08-12-2008, 13:44
JesseK's Avatar
FRC #1885 (ILITE)
What is the bearing/hole plate on the end of the telescope for? It looks like a great place for a sensor, or for the wiring/tubing to come out of, but I could be wrong.
GitHub
Unread 08-12-2008, 14:50
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
When the game is unveiled... ask yourself how many degrees of freedom you actually NEED. Beachbots, FTW.
-John
Unread 08-12-2008, 15:48
Originally Posted by JVN View Post
Beachbots, FTW.
-John
Are you sure about that one, John? (OK, OK, that one has three. One to go up, one to go over, and one to lengthen.)
Since then, one degree of freedom plus any extras on the base.
Unread 08-12-2008, 15:50
Spark The Ancient
Thanks a lot Kevin Sevcik, that is relly helpfull. what is funy, is that we just learned this stuff in phsiscs class!
Hopefully, an arm like this could be controlled with a phisical model, similar to the controller I built my sophmore year (it won the innovation in control award by the way).
The gearbox that is on there right now is for the extension, as that math was easy enough to figure out.
the upper arm's articulation technically will operate like a 4-bar linkage, but still be moveable (similar to team 60's arm design)
Unread 08-12-2008, 15:56
JVN JVN is offline
@JohnVNeun
Eric,
As noted by the "FTW" I was referring to their WINNING robot, not it's ancestors.
I've been a huge fan of the super-elegant 2005, 2007, 2008 Beachbot robots. In 2005 & 2007 in particular I loved the 4-bar designs my teams utilized, but then saw that 330 could score as well or better with just a single joint. Simplicity yields elegance.
-John
Unread 08-12-2008, 15:59
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
If I am not mistaken that would be the tensioner plate, and if it is, you could also attach a sensor at the point, or you could place it inside the gearbox extension which might be safer
Think Poof
Unread 08-12-2008, 16:46
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I would have to say this looks like a fun CAD project to work on, but very unpractical to combine those two systems in real life. By adding a telescoping section to a poof style 2-jointed arm you are basically adding a redundant system to achieve the same goal. The whole point of the lower joint on the 'poof' style arm is to extend the arm to reach farther, higher ect. which can also be achieved by a 'pink' style telescoping arm with a lower joint. So unless you really can't achieve your goal with a 'poof' or 'pink' style arm, I guess this system could work... but that's very unlikely and makes this kind of system unnecessary.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
pic: What we have so far DarkFlame145 Extra Discussion 3 14-01-2008 06:36
Couldn't have done it w/out 67 and 68 team66t-money Thanks and/or Congrats 5 16-03-2005 20:19
What cool thing have u done this summer? DarkRedDragon Chit-Chat 45 21-08-2003 14:39
What is the Craziest thing YOU have done with duck tape Jon K. Chit-Chat 70 07-04-2003 00:20
What have you done in past years? Lora Knepper Chairman's Award 3 03-06-2001 18:23
