Go to Post In FIRST, success = inspiration. - Daniel Brim [more]
Unread 12-08-2008, 01:34 PM
Re: pic: Cheap 6WD
Originally Posted by s_forbes View Post
Actually, having the transmissions in the back has some neat advantages. Since the center wheel is dropped, the rear wheels don't carry as much load.
I don't see your reasoning. The way I'm looking at it, the rear wheels carry more load than if the center wheel were not lowered (up to half the robot's weight or even more, depending on the center of gravity). They just do it intermittently -- which seems likely to cause greater shock loads on the axle when the robot rocks backward.
pic: re-modified 6wd spc295 Extra Discussion 15 11-19-2008 03:14 PM
pic: 6wd chassis spc295 Extra Discussion 21 11-10-2008 09:00 AM
pic: 6WD Module Madison Technical Discussion 20 01-12-2007 10:09 AM
