pic: New Chassis Concept
Re: pic: New Chassis Concept
This is still being worked on but if you have comments, questions or suggestions feel free to post them.
Looks good!
With all that pocketing on the front and back rails, I would consider adding a crossbeam in the middle. |
its best to build the chasis heavy and make lighter by cutting holes out as you need that way you dont sacrafice too much strenght. Basic tankdrive?
what is the wall thickness on the extrusion?
if it is 1/8" and pocketed, I would recommend switching to 1/16" and don't pocket it. Similar weight, less work, and depending on the pocket pattern, stronger. |
Current holes are just to get an idea of how much weight can be removed while keeping structural integrity. |
#7
.15 is not a common commercially available thickness for extrusion, are these made from sheet metal?
Either way, that's some thick stuff, for that tall of a frame member, I'd recommend thinner material with less pocketing. |
#8
Great job on this and it looks nice. The thing I like about FIRST is that there are so many different designs and they each have pro's and con's to them. This design is a great design and probably a pretty light chassis. Just include someway of tensioning the chain (Andymark's New Chain Tensioner is coming out!). BTW great CAD JOB, more views would be nice.
#9
Its McMaster 1630T14. So you recommending something thinner with less pocketing. Thats doable. Im still playing around with best ideas for removing weight and keeping strength. |
#10
If you do use it, find another supplier; $66 for 5' of that is ridiculous. |
#11
EDIT: Not at my computer but I think it was like 1.2 a foot with pocketing and reducing leg length. Last edited by chris31 : 08-12-2008 at 21:15. |
#12
You could try dropping the middle pairs of wheels just like a half an inch, to make it easier to turn...
#13
1/8 inch or 3/16 inch drop is usually sufficient.
#14
Ok. I'm still reading up on differnt distances to drop the middle wheel.
#15
I would also reccomend against using C-channel. It is a major pain to machine. I think you'd be a lot happier with your results if you made this out of 1x2 extrusion. |
| pic: Concept Frame | armoredvehicle | Extra Discussion | 6 | 16-12-2007 20:55 |
| Interesting new robotic automation concept | Grant Cox | General Forum | 2 | 15-05-2007 11:22 |
| pic: Claw^2 Concept | CD47-Bot | Extra Discussion | 8 | 06-02-2004 14:08 |
| pic: Crab Concept 6 | CD47-Bot | Extra Discussion | 13 | 14-11-2003 22:03 |
| A New Concept for the Tournament Structure in 2004 | Andrew | Rules/Strategy | 38 | 07-07-2003 12:30 |
