Go to Post FRC: so inspiring, even car thieves can't handle it. - evanperryg [more]
Unread 23-06-2002, 23:44
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: last years speed controllers.....
Posted by Al Skierkiewicz at 1/28/2001 10:07 AM EST
Other on team #111, Wildstang, from Wheeling High & Rolling Meadows High and Motorola.
In Reply to: Re: last years speed controllers.....
Posted by Al Skierkiewicz on 1/28/2001 10:01 AM EST:
Additional...
2.1.2 Rotating Light
A Relay Module must be used to power the rotating light provided in the kit. The light must turn on
when the robot is enabled and turn off when the robot is disabled. The control system will provide
this functionality automatically when a Relay Module is connected to relay output 8 on the Robot
Controller and the default program is running. Wire the light such that the black power lead is
connected to M- and the red power lead is connected to M+ on the Relay Module.
I am still looking for modification reference but I believe as last year, the rotating light is on the "do not modify" list.
[IMG] code is Off
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
speed controllers archiver 2000 5 24-06-2002 00:19
Capacitors on speed controllers archiver 1999 7 23-06-2002 22:09
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
