Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 08-12-2008, 20:39
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: pic: New Chassis Concept
Originally Posted by NickE View Post
Looks good!
With all that pocketing on the front and back rails, I would consider adding a crossbeam in the middle.
I was waiting to see how the electronics will drop inside and chain paths before adding crossbeams of any sort into the chassis.
what is the wall thickness on the extrusion?
if it is 1/8" and pocketed, I would recommend switching to 1/16" and don't pocket it. Similar weight, less work, and depending on the pocket pattern, stronger.
The walls are .15 aluminum.
Originally Posted by ironbears View Post
its best to build the chasis heavy and make lighter by cutting holes out as you need that way you dont sacrafice too much strenght. Basic tankdrive?
Current holes are just to get an idea of how much weight can be removed while keeping structural integrity.
Unread 08-12-2008, 20:44
AdamHeard's Avatar
Lead Mentor
.15 is not a common commercially available thickness for extrusion, are these made from sheet metal?
Either way, that's some thick stuff, for that tall of a frame member, I'd recommend thinner material with less pocketing.
Unread 08-12-2008, 20:47
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Great job on this and it looks nice. The thing I like about FIRST is that there are so many different designs and they each have pro's and con's to them. This design is a great design and probably a pretty light chassis. Just include someway of tensioning the chain (Andymark's New Chain Tensioner is coming out!). BTW great CAD JOB, more views would be nice.
R.C.
MadTown Robotics Team 1323
Unread 08-12-2008, 20:55
Team 2021 Captain
AKA: Chris Davidson
Yeah. I have a few ideas starting to be drawn. Just nothing is final in CAD yet.
Its McMaster 1630T14. So you recommending something thinner with less pocketing. Thats doable. Im still playing around with best ideas for removing weight and keeping strength.
Unread 08-12-2008, 21:02
AdamHeard's Avatar
Lead Mentor
Oh wow, that's THICK stuff. The base is .15 thick, but the legs are .26. HEAVY stuff, 2.2 lbs a foot or so.
If you do use it, find another supplier; $66 for 5' of that is ridiculous.
Unread 08-12-2008, 21:12
Team 2021 Captain
AKA: Chris Davidson
I was hoping to mill down the length of the legs of the U channel. Do you have a reccomentation on a better replacement for this U channel that would work better. Thanks.
EDIT: Not at my computer but I think it was like 1.2 a foot with pocketing and reducing leg length.
Unread 08-12-2008, 21:14
Musicninja's Avatar
Musicninja Musicninja is offline
FRC #3038
Musicninja is an unknown quantity at this point
You could try dropping the middle pairs of wheels just like a half an inch, to make it easier to turn...
You just lost the game.
Unread 08-12-2008, 21:17
NoahTheBoa's Avatar
NoahTheBoa NoahTheBoa is offline
AKA: Noah Tomaszewski
FRC #0968 (RAWC)
NoahTheBoa has a spectacular aura aboutNoahTheBoa has a spectacular aura about
Send a message via AIM to NoahTheBoa
1/8 inch or 3/16 inch drop is usually sufficient.
Unread 08-12-2008, 21:19
Team 2021 Captain
AKA: Chris Davidson
Ok. I'm still reading up on differnt distances to drop the middle wheel.
Unread 08-12-2008, 21:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
1/2" is too much. Your robot will be a seesaw. I would recommend 0.125-0.1875.
I would also reccomend against using C-channel. It is a major pain to machine. I think you'd be a lot happier with your results if you made this out of 1x2 extrusion.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-12-2008, 09:02
rally_racin'_94's Avatar
rally_racin'_94 rally_racin'_94 is offline
Rookie
AKA: Cody
FRC #2062 (C.O.R.E)
rally_racin'_94 is an unknown quantity at this point
6 wheel drive???
or less??
"Confidence is the key to great acts of courage"
"pain is weakness leaving the body"
Unread 11-12-2008, 09:04
Rookie
AKA: Cody
FRC #2062 (C.O.R.E)
how would you get it to turn with 6 wheel drive because all the wheels have a sprocket
Unread 11-12-2008, 09:58
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
if all the wheels are powered it shouldent have a problem turning............
its tank drive presumably not car steering.........
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 11-12-2008, 11:43
Team 2021 Captain
AKA: Chris Davidson
Yes, its tank drive.
Tank drive. Its been done over and over again successfully.
Unread 08-12-2008, 22:45
R.C.'s Avatar
Chris I like your stuff and if you need any help with CAD, please email me. Try using 1x2 aluminum. We have using a 1/16 wall and it is fairly light. You can even pocket some out on the sides but none on the top. We created a frame that had a ton of cnc work and played battle bots with it to see if it would crumble. Plus stress testing told us it would be fine. Make sure you have a safety factor of 10 ((Just to be extremely Safe))
R.C.
pic: Concept Frame armoredvehicle Extra Discussion 6 16-12-2007 20:55
Interesting new robotic automation concept Grant Cox General Forum 2 15-05-2007 11:22
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
A New Concept for the Tournament Structure in 2004 Andrew Rules/Strategy 38 07-07-2003 12:30
