Go to Post Remind me again why anyone, my team included, is stupid enough to keep going to week 1 events? - Madison [more]
Unread 09-12-2008, 08:45
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: pic: 8WD 'Suspension' Chassis Concept
Suspension ususally implies some sort of spring/shock setup to allow flexible wheel movement but return it to a set position--kind of like how a car sits on its springs/struts. How would you accomplish this?
Perhaps you could run a pair of universal joints between the output shaft from a gearbox to the input shaft of the "pod" to allow for movement of the suspension, then run chain/gears to the pair of wheels. This would allow for the transmission to be mounted solid. Question is...do you have the overall width to run that setup on both sides of the robot? Just a suggestion to help move your idea forward...
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
pic: New Chassis Concept chris31 Extra Discussion 35 11-12-2008 11:43
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
