Go to Post Do what you want. Deal with the results. - Andy Baker [more]
Unread 08-12-2008, 22:38
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
pic: 8WD 'Suspension' Chassis Concept
Unread 08-12-2008, 22:46
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Re: pic: 8WD 'Suspension' Chassis Concept
I'm looking at this and I am curious as to how you plan on powering the wheels. I realize its a rough sketch, but given the amount of joints it looks like you would need a rather complex system to transfer power around the hinges. Assuming that you were planning on using chains, you would need at least two separate spans to get to one side, as far as i can see, and the space for running them looks tight. One last thought, did you consider how bumpers could be mounted?
Unread 08-12-2008, 22:52
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
BE VERY CAREFULL! 342 tried a 8 wheel drive system with 4 independent drive pods. We faught with this drive system '05 and '06. On paper it was ingenious, but we had a lot of problems turning and machanical break downs, and it really hurt us in '06. This system was probably the coolests looking and worst functioning drivetrains we have tried.
We went back to the kiss method with great results. Your plan sounds good, all I'm saying is to weigh the beneifits of this system agaist the simplicity and reliablity you will sacrifice. If it works, more power to you.
P.S. sorry the pics are so big
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 08-12-2008, 23:00
EricH EricH is online now
One year I proposed an 8WD to my team. It didn't go over real well. That might have something to do with it being two pairs of pods, power-rotated as pairs. One wheel of each pod would have been an "interesting" mecanum-type wheel and the other a standard KOP wheel of the same size. Think each pod from ^^ tied to the one directly opposite it and rotated by motor.
Unread 09-12-2008, 08:45
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Suspension ususally implies some sort of spring/shock setup to allow flexible wheel movement but return it to a set position--kind of like how a car sits on its springs/struts. How would you accomplish this?
Perhaps you could run a pair of universal joints between the output shaft from a gearbox to the input shaft of the "pod" to allow for movement of the suspension, then run chain/gears to the pair of wheels. This would allow for the transmission to be mounted solid. Question is...do you have the overall width to run that setup on both sides of the robot? Just a suggestion to help move your idea forward...
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 09-12-2008, 14:12
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by hipsterjr View Post
BE VERY CAREFULL! 342 tried a 8 wheel drive system with 4 independent drive pods. We faught with this drive system '05 and '06. On paper it was ingenious, but we had a lot of problems turning and machanical break downs,.....We went back to the kiss method with great results.
Both of these designs look really cool.
Although, I think the reason you had such great difficulty is that this design creates a huge amount of "scrubbing" force when trying to turn. This extra friction is excellent when going straight, but adds a LOT of extra stress on the drive train once you start turning. Just to demonstrate my point: A dropped center wheel system, whether 2, 4 or 6 wheel drive, overcomes this because it shortens the wheelbase while maintaining a wide track. You get a much greater moment of inertia to overcome the "scrubbing" forces with that type of drive train.
Unread 09-12-2008, 15:43
AdamHeard's Avatar
Lead Mentor
I like suspensions, I'll admit their cool, but so far FIRST hasn't given us an obstacle that truly needed a suspension to climb. Sure, a base with a suspension could beat out an average designed base for some obstacles, but I believe a 6 wheel can be made to climb anything.
Unread 09-12-2008, 20:05
hipsterjr's Avatar
AKA: CJ
I agree. I also believe a dual independent track design would be a simple approach. But if you decide to screw simplicity, you could always go with the "Big Dog" design .
Unread 09-12-2008, 22:00
JAZAD1's Avatar
JAZAD1 JAZAD1 is offline
Assisant Coach
AKA: Zach
FTC #4105 (Teal Toranadoes)
JAZAD1 has a spectacular aura aboutJAZAD1 has a spectacular aura about
That’s a great idea and it looks really cool in the pic. I just don't think that’s it is a practical idea unless you know exactly what you are going to need it for. Its a great idea and I will start to work on one now just b/c it looks so cool. Just an idea you could make each wheel pod with its own suspension system so that it could climb things better I’ll try to draw something up and post it at a later date.
2010 IRI FRC Second Place Finisher
2010 International Championship Coopertition (Galileo)
2010 International Championship #1 Seed (Galileo)
2010 NC FRC Motorola Quality Award
2010 NC FRC Regional Winner
2010 VA FRC Regional Winner
2010 VA FRC Engineering Inspiration
2009 VA (S) FTC Inspire Award
2009 VA(S) FTC Division Finalist
2009 VA FTC PTC Desgin Award
2009 International Championship Spirit Award
2009 VA FRC Regional Champion
2009 VA Regional Chairman's Award
2009 VA Website Excellence
2008 VA FTC Regional Champion
2008 VA FRC Regional Champion
2008 VA Regional Chairman's Award
2008 VA Xerox Creativity
pic: New Chassis Concept chris31 Extra Discussion 35 11-12-2008 11:43
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
