Go to Post You are joining the greatest family in the world, FIRST, because we all strive to practice GP. - Ken Loyd [more]
Unread 09-12-2008, 14:52
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: FRC 1771 East (West) Coast 8wd drivetrain
Unread 09-12-2008, 14:53
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: pic: FRC 1771 East (West) Coast 8wd drivetrain
what's the side rails made out of?
now if i can only come up with a south coast drive..........
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 09-12-2008, 15:03
AKA: Sean
The frame is made up of 2"x1"x.125"thickness aluminum and 1"x1" aluminum all welded together. The entire frame right now without any work done to lighten it is 9lbs, and should be very stiff. I also have bumper mounts planned but I haven"t modeled them yet.
Mentor 2415
Unread 09-12-2008, 16:20
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Looks good but one question, how are you planning to run the chain? It looks like it will be a costly change during competition if you are planning on having the chain go through your support beams, I know it would be a lot easier to take the chain off as a whole instead of finding the master link and taking a chain off that way.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 09-12-2008, 16:34
AKA: Sean
If you look closely at the model, the round silver discs one the inside of the frame are actually sprockets bolted to the axles. The chain will run from the transmission to the 2 center wheels and then from the center wheels to the outer wheels. It will be incredibly easy to replace a chain although I doubt we will have to as I have never broken a chain. We will also be using 25 series chain. everything about this drivetrain is incredibly easy to work on. We can switch a wheel in a matter of seconds to keep the tread fresh. Also tensioning is super easy.
Mentor 2415
Unread 09-12-2008, 16:39
AdamHeard's Avatar
Lead Mentor
Why not direct drive a wheel?
Also, you should simplify the wheels to make them more efficient and easier to make.
Unread 09-12-2008, 16:50
AKA: Sean
I chose not to direct drive a wheel so that we don't have to use custom gears or use an extra stage of gears. Also with this layout, the gear ratio can be switched very quickly by changing a sprocket size. This transmission uses almost no custom parts so it could be put together very quickly. I don't see enough benefit in directly driving a wheel to make it worth the machining effort. Also the way the motors are oriented at the bottom of the transmission helps lower the center of gravity more than if the motors were at the top of the transmission.
The wheels are actually incredibly simple. They will be made from a length of aluminum tube, and 2 separate plates of aluminum that will be laser cut to form the spokes. The entire thing will then be welded. The reason I did it this way is that we are sponsored by a sheet metal shop that does not have any cnc milling equipment, but has plenty of laser cncs, and the material to make these wheels is much cheaper than buying the billet necessary to machine a single piece wheel from.
Mentor 2415
Unread 09-12-2008, 17:08
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
I'm sure all 8 wheels are not touching the carpet, so which ones have been raised/lowered?
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 09-12-2008, 17:25
AKA: Sean
the middle 4 wheels have been dropped by .175"
Mentor 2415
Unread 09-12-2008, 17:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's a neat way to do it...it's how most automotive wheels have been made since the 1930s, although they use steel.
How does the center of the wheel work, where the spokes attach to the axle?
Unread 09-12-2008, 17:40
AKA: Sean
Yeah it is very simple and a lot cheaper. The spokes have a 7/16" hex cut in them that interfaces with a hex on the end of the axle. The wheels will be held on either with a bolt tapped into the end of the axle or with a ring clip. The axles are machined out of 7075 aluminum and have a hub on the opposite side to bolt plate sprockets so that we don't have to use hubbed sprockets, and we can have custom sprockets cut very cheaply (free )
Mentor 2415
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
pic: FRC 1771 Concept Drivetrain sdcantrell56 Extra Discussion 7 09-11-2008 14:42
pic: FRC 1771 Drivetrain sdcantrell56 Extra Discussion 24 02-09-2008 17:05
8WD drivetrain? David Sherman Technical Discussion 16 09-04-2006 17:32
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
