Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 24-11-2008, 21:48
koka230 koka230 is offline
AKA: Scooter
FRC #0388 (Maximum Oz)
koka230 is an unknown quantity at this point
Send a message via MSN to koka230
New Control System
Went to Richmond this weekend to the FIRST seminar and saw the new control system and was quite amazed by it. They kept mentioning a industrial version of the crio unit. Does anyone know what exactly it was made for, it might be a hint toward the game?
(If already discussed ignore this, haven't been on this website in a while )
Unread 24-11-2008, 22:20
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: New Control System
Generally industrial quality indicates extended shock, vibration, and temperature specifications.
http://www.ni.com/compactrio/whatis.htm
Unread 24-11-2008, 22:22
AKA: Scooter
well my point was what is the unit use for or on that is what i am asking
Unread 24-11-2008, 22:42
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
It is used for data-acquisition and control, like when they monitor the big oil rigs. I'm sure it was picked because NI was giving a good deal and it will work well for this competition in general, not as a game hint specific to this year. More info can be found at:
http://zone.ni.com/devzone/cda/tut/p/id/5508
scroll down to "Applications"
Unread 24-11-2008, 22:43
AKA: Scooter
ah, just a thought
Unread 25-11-2008, 08:15
The non-FIRST version of the cRIO is used for many things. Three in particular come to mind:
  • Beam collimators for the Large Hadron Collider at CERN, controlling the highest energies used in any machine in the world
  • Adaptive optics mirror control for the Southern African Large Telescope, the biggest optical telescope in the world
  • The highest-resolution atomic force microscope in the world
It's a very rugged, very capable, very common platform for embedded control systems.
Unread 01-12-2008, 21:43
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I think the control system may be too rugged... that thing weighs way too much. You can tell by the design of it that it was made for a table-top operation, and not for a weight-restricted robotics competition. I wonder if they will let us lighten the cast-steel casing which is a little overkill in my opinion... I took a look at it today and the circuit board comes off easily, so it could be done.
I'm not complaining that they gave us a very powerful new control system... I just hope they will let us lighten it (if the weight limit doesn't increase), because it doesn't look like they changed the design of the table-top version for our robotics competition.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 02-12-2008, 08:45
The cast steel is actually a lightweight cast of a magnesium alloy. If you've removed the back plate, perhaps you noticed how little the flat piece weighs. But put the pieces together and it does more and weighs more than the previous system.
There have been other discussions about the overall weight of the new components, but in the end, it will be the same for all teams. I'm sure you will not be allowed to punch holes in the cRIO, so you can spend your strategic planning time on something else.
Greg McKaskle
Unread 02-12-2008, 09:01
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Greg McKaskle
And here I thought we needed to provide air-cooling for the modules!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 09-12-2008, 16:29
waialua359's Avatar
AKA: Glenn
Does anyone have an estimated date on when we can purchase additional spare components for the new control system?
Andy?
Thanks.
Unread 09-12-2008, 16:36
AdamHeard's Avatar
Lead Mentor
Andy?
Thanks.
http://controlsystem.neofra.com/2009...l-system-parts
details it nicely.
AndyMark's side claims Dec 10th for most, 18th for the Driver Station.
NI claims starting December 1st, but calling that number got us nowhere after 3 transfers.
The Jaguars can be bought now from digikey, and obviously the networking equipment and joysticks can be bought from the usual places (I imagine newegg.com or amazon.com would be the cheapest).
Unread 09-12-2008, 16:38
waialua359's Avatar
AKA: Glenn
Thanks for the info.
Great link! We knew about the jaguars and ordered them already so far.
-Glenn
Unread 09-12-2008, 16:44
AdamHeard's Avatar
Lead Mentor
-Glenn
No problem, if you guys somehow get the number for the cRIO to work, post what you did or who you talked to... We were transferred several times and everyone we spoke to was clueless.
Unread 09-12-2008, 18:56
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
I used the number posted in the forum 1-866-511-6285 and got transfered to sales for my zip code. The person that I talked to had just heard about the program, but was not setup with all the info to take my order. He did promise to find out and send me some email tomorrow regarding what needs to be done to order the parts.
He did have the info for the pricing (he said $749.75) and said he had received info about the program just today.
I'll provide more feedback when I get the email from NI tomorrow. It sounds like they are almost up and running to supply backup control systems.
Unread 10-12-2008, 02:07
waialua359's Avatar
AKA: Glenn
Thanks, look forward to seeing you folks again in Oregon!
new control system Sam2197 FRC Control System 2 22-11-2008 13:17
New control system? David55 Rumor Mill 2 29-12-2006 08:28
New control system ... new forum. Brandon Martus Control System 0 06-01-2004 15:05
New Control System Photos archiver 2000 18 23-06-2002 22:13
New Control System? smokescreen Rumor Mill 4 07-03-2002 15:48
