Go to Post While money can create fancy-looking robots, it does not always create game-winning ideas. - Karibou [more]
Unread 09-12-2008, 20:33
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Exclamation Problems with Victor 884
The electrical team (and me) met today to finish installing the new control system and we ran into a problem. Our Victor 884 PWM's do not work with the on board code provided by FIRST. We were wondering if
1) Any other teams are having this problem
2) We are required to use the Jaguars this year
3) We could program the DS to use the Victors
We know that everything works, because we tested a Jaguar also and it worked fine.
Any information would be extremely helpful to the FEDS.
Thank you,
Alex Dinsmoor
Team 201
Programmer/Electrical
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 09-12-2008, 20:43
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Problems with Victor 884
Jaguars are not mandatory, victors will still be available. Did you check the programing to see if it is set for jags or 884s? Also what do you mean by
The DS has no programing except firmware and team number, possible you were talking about the cRio.
- Arizona North
Unread 09-12-2008, 20:44
AdamHeard's Avatar
Lead Mentor
Victors are legal, but I believe you must change the code to the specific speed controller (and it's set to jaguars by default) as it generates a different PWM for each type.
Unread 09-12-2008, 20:51
FRC #0201 (FEDS)
Originally Posted by rtfgnow View Post
Also what do you mean by The DS has no programing except firmware and team number, possible you were talking about the cRio.
Yeah I meant the cRio, it's been a long day of working/school
That's good to hear. We were going to reuse our old electronics board, and didn't want to use the jags because of their size. Once we begin to program we will be sure to take note of that
'08, '09, '10
Unread 09-12-2008, 21:31
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
I know the large size is an immediate turn off, but please keep an open mind about using the Jags. The linearity and slow speed control compared to the Victors is night and day. See www.chiefdelphi.com/forums/showthread.php?t=68714 for more info on this. If you are serious about accurate controls this year make sure you make an effort to test them out.
Unread 09-12-2008, 21:41
The difference between the victor, jaguar, and servo code will not keep any of them from receiving a signal if programmed for another type. If a Victor is programmed with the Jaguar class, the victor's output will saturate very early. If a Jaguar is programmed with the victor class, the Jaguar's output will never saturate. The deadbands and neutral points will also be a little off.
I'd guess that the problem is that the PWM cables aren't plugged in fully on the Victor. It can be quite difficult to get it in, because of the retaining features.
Unread 09-12-2008, 21:50
FRC #0201 (FEDS)
Hmm, that could be it. I will be sure to check those the next time we meet.
@trilogy2826 I will need to investigate into the jags further. Is it possible to make a tower of sorts out of two of them? I know you need a half inch clearance between them, but in order to fit them on we would need to do something along the lines of stacking to be able to have enough space.
'08, '09, '10
Unread 10-12-2008, 07:42
I would not stack either type of speed control. The top of the fans on both types need to be free to move the cooling air over the power devices. The size of the Jaguar is a distinct downside to using these devices in comparison. Remember that in all electronics there is a point on the temperature curve where the device just starts to do what it wants. Sometimes to the point of self destruction.
Unread 10-12-2008, 09:33
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
do the jags have a feedback for speed so that you can sync all the motors to the same speed to make sure you go straight in auto.
Unread 10-12-2008, 11:37
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Not till CANBUS next year.
Unread 10-12-2008, 18:02
FRC #0201 (FEDS)
That's a good point. I don't want our robot to just go out of control!
Is there anything we can possibly put the jags over on a raised platform?
Here is our electronics board (sorry for so so detail): http://www.chiefdelphi.com/media/photos/32126
'08, '09, '10
Unread 10-12-2008, 20:53
Alex,
Normally I suggest that speed controllers be mounted near the motors they are controlling to minimize the wire runs. There is nothing in the picture to prevent you from using perf stock or a piece of lexan on the uprights across the back of the robot. Then you can mount the controllers vertically on that. Since the Jaguars have mounting holes in the sides, you can use threaded standoffs to elevate every other one and using the standoffs, rotate the elevated controllers 90 degrees to allow you to stagger them and fit more in the space. That way, no fans are occluded and the wiring is spaced out. Also, mounting the controllers so that they are front to back rather than side to side, works well too. This allows them to be mounted next to each other and touching. The wiring works better that way as well and the only drawback is getting the PWM cables attached. In your actual robot, don't forget to mark your wires and controllers. You can get 3M wire marking tape from Digikey. It is expensive (about $30 for a dispenser with all 10 EIA colors) but is well worth it when you are trouble shooting.
Unread 10-12-2008, 21:04
DonRotolo's Avatar
Back to humble
FRC #0832
We completed out Out of The Box test last night, with one Jaguar and one Victor connected - both worked fine (with the effects Joe noted) with no changes to the OTB code.
Stacking anything that tends to generate a lot of heat isn't always a good idea, but in some cases if you manage the heat other ways, it's not always fatal. One example is if it controls a small load, just a few Amps (and thus doesn't get that warm), another example is if there is natural or forced airflow that ensures good cooling.
Unread 10-12-2008, 21:29
FRC #0201 (FEDS)
Did you use the new Victor that came with the kit, or an older one from a previous year?
Alex,
Normally I suggest that speed controllers be mounted near the motors they are controlling to minimize the wire runs. There is nothing in the picture to prevent you from using perf stock or a piece of lexan on the uprights across the back of the robot. Then you can mount the controllers vertically on that. Since the Jaguars have mounting holes in the sides, you can use threaded standoffs to elevate every other one and using the standoffs, rotate the elevated controllers 90 degrees to allow you to stagger them and fit more in the space. That way, no fans are occluded and the wiring is spaced out. Also, mounting the controllers so that they are front to back rather than side to side, works well too. This allows them to be mounted next to each other and touching. The wiring works better that way as well and the only drawback is getting the PWM cables attached. In your actual robot, don't forget to mark your wires and controllers. You can get 3M wirk marking tape from Digikey. It is expensive (about $30 for a dispenser with all 10 EIA colors) but is well worth it when you are trouble shooting.
All of these are really good ideas, I will be sure to pass these along to my mentor! I'm glad we used zip ties to attach all of the components of our electrical board, now no one can make to big of a fuss if we decide to rearrange the board.
'08, '09, '10
Unread 21-12-2008, 12:20
DonRotolo's Avatar
Back to humble
FRC #0832
It was an older one from a previous year.
Problems with victor blowing JamesBrown Electrical 18 17-02-2008 20:36
Victor 884 Problems Team 135 Electrical 12 05-02-2008 13:24
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
