Go to Post Angry Teams will not get the field going any quicker trust me on that! - mtaman02 [more]
Unread 09-12-2008, 20:38
CraigHickman
Posts: n/a
pic: West Coast Drive: Spokane Style
Unread 09-12-2008, 20:40
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: pic: West Coast Drive: Spokane Style
if you were thinking about climbing, why not use a 2 speed?
i like this design escpecially the bumper mounts
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 09-12-2008, 20:43
AdamHeard's Avatar
Lead Mentor
2 CIMs geared for 10fps doesn't seem traction limited (assuming roughtop/wedgetop tread).
Unread 09-12-2008, 20:46
Don't see the correlation between the two things...care to explain? Plenty of 'bots did just fine w/o any shifting in 06, so I don't see what you mean by that.
Unread 09-12-2008, 20:55
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
You definitely do not need a 2 speed transmission to climb things. All a 2 speed would really help with is allow you to be a bit more precise in maneuvering. The important things to consider when having to climb are approach/departure angle, breakover angle, center of gravity, and traction.
I do really like this design although I do favor 2 speed transmissions for the ability to push and to be agile when you want. I'm glad Ive inspired a little West Coast off of sorts. Who's next?
O and how much does it weigh?
Mentor 2415
Unread 09-12-2008, 20:57
Originally Posted by sdcantrell56 View Post
Who's next?
Soon my good man, soon
Unread 09-12-2008, 21:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Just guessing...the frame is made of 1/8" wall 1x2" aluminum tubing? welded together?
Looks very orthodox, and a good design!
Unread 09-12-2008, 21:07
CraigHickman
Posts: n/a
I hate to say it, but this design was cooking long before you brought it up. It was you bringing it up that inspired me to post the render. Weight is around 35 for the entire assembly, and that's with chain (not shown in the render)
The bumper mounts aren't actually finished in this render. The final versions will have 4 .25" thick plates welded to each of the jutting extrusions pieces on each side. Each plate will have two 1/4-20 holes for mounting the bumper lock bars, something I've been cooking up to allow easy to swap bumpers. Imagine something akin to a door hinge, that allows a bolt to be put in the top on each peg to secure the side bumpers.
EDIT: Yeah Squirrel, it's all 2x1x.125 wall extrusion. The goal was to keep the chassis to only one material to keep the cost down, and the BOM simpler
Unread 09-12-2008, 21:13
AKA: Sean
O I know it's been cooking for a while. You've had a design similar to this floating around for a while now. It's good though to see how different people change and interpret a well known design.
Mentor 2415
Unread 09-12-2008, 21:22
CraigHickman
Posts: n/a
Actually, after reading over what you said, let's see how many iterations of the West Coast Drive there are out there! If you've got one designed, put the render up on www.tinypic.com and throw it up here!
Unread 09-12-2008, 21:55
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Nice design, that kind of set up has been proven to work tons of times. What kind of guts do you have in the transmissions? Are they completely stock components (minus sideplates), or do some of the shafts/gears need machining?
It certainly isn't, the traction limit for roughtop or wedgetop drivetrains (2 CIMS) is closer to 6.5 ft/sec for a full weight robot. Still, we ran wedgetop tread on our single speed robot last year at about 11 ft/sec and didn't have any problems. Of course, we didn't have to push anyone either...
I made one a little while ago that's similar to yours in that it is just a small single speed drive base, but uses cantilevered dead axles instead of live axles. Not really west coast, but still... Comes in to about the same weight as yours, too, about 35 lbs with chain (says inventor). The transmissions are about as itty bitty as they can be.
Unread 09-12-2008, 22:52
run the trap!!!
Team Role: Human Player
Ourselves and team 368 built one with 80/20 (or Bosch). Team 100. Team 368. 368's actually had a really cool pneumatic break that shot into a hole in one of their drive sprockets.
Why is cantilevered better than non-cantilevered? Beats me. We won't be doing this again.
-Philip J. Fry
Unread 09-12-2008, 22:55
CraigHickman
Posts: n/a
Chassis weight. You need less chassis material for a cantilevered drive base. There's no need for an outer frame rail, which definitely takes weight down.
Unread 09-12-2008, 23:07
Hate to be uninformed, but what exactly is a cantilevered wheel/frame? Pics of specifics would greatly help.
Unread 09-12-2008, 23:10
MrForbes's Avatar
AKA: Jim
Cantilevered means the axle is supported at one end or a the center, non-cantilevered the axle is supported on both sides of the wheel.
"West Coast" drive? pogenwurst Technical Discussion 32 17-12-2008 19:50
pic: West Coast SS mounting 3 AdamHeard Extra Discussion 2 17-06-2008 13:11
pic: West Coast Altered Alex.Norton Extra Discussion 25 13-06-2008 00:13
pic: West Coast Collaborationz and Team 254 Present phrozen solyd Robot Showcase 22 28-02-2005 01:31
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
